thickest wheel spacers for stock wheels?
^I saw the writeup it looks good. Oh and 5 millimeters = 0.196850394 inch. If you want close to .5" then go with 10mm but you may want longer studs to be on the safe side.
If you really want to fix that gap, then go with Hubcentric Wheel adapters instead of spacers. These are basically spacers but with new bolts attached to the spacer itself- refered to as the "thread-on" type of spacer or "DRM". You can get them in 15mm, 20mm, and 25mm and up. Your best fit is probably the 20mm or 25mm. just make sure that they are HUBCENTRIC and not that garbage they sell on ebay. Also, make sure that what ever rim you are using will accomodate the old lugs on the back side of the rim. Get either the H&R adapters, or Kics Project spacers. Just know that Kics is a two piece system, you have to purchase the hub rings seperately.
^Those do work I just don't trust them. I mean if they fail your rim just falls off the car. When using longer studs and spacers if one fails you still have the other ones to fall back on.
http://cgi.ebay.com/ebaymotors/5x114...spagenameZWDVW
I have those on my ES in the back. I've been using them for a year and no problems.
Only thing is 15mm will not make the wheel sit flush with the fender, if i was to do it again, i'd prolly go with 25mm
Funny though, apart from those individuals that race or drift, I have yet to read about any normal driver that has lost his wheel using a spacer! Not that is hasn't happend, I just haven't found a thread on it.
I will agree with this in all my reading though - adding either of these additional parts to the suspension increases risk and widening your wheel base puts a little more strain on the suspension itself. Having said that, a lot of NEW Porche vehicles have some form of spacer on their back wheels.
One last thing to add. With your stock wheel on the car and NO spacer, you'll notice that the fronts are actually a little wider than the rears. So if you decide to widen all 4 wheels, I would suggest purchasing smaller front spacers than the rear. Like 15mm fronts and 25mm rears.
