Car shuts off on inclines...
Old 12-09-07, 10:36 PM
dundfaukus
dundfaukus's Avatar
Default Car shuts off on inclines...
My dad's 95 ES ran perfectly fine for past year or so, we even had a new transmission put in when it gave him problems.
Car idles perfectly in park and neutral, but when I put it in drive its acting like it is choking. When I try to go it'll be jerking forward until it gets up and going...which still feels like it lacks power at wide open throttle.
So I was tinkering around to see if it was in all the gears, even reverse...it was. I drove around a bit more and the jerking got somewhat better as car warmed up, so I decided it pull it up into my garage to check it out...my driveway to garage is on a 45deg incline. Right as I pulled up onto it, the car died and would not turn back on until I neutraled on flat surface...then started up just fine(still jerked).
There is no check engine light or any type of O/D light on at any time. Any ideas what it may be? Lack of fuel? I have not looked into the car much today, but if anyone has experienced this please share..
Old 12-09-07, 10:39 PM
92ES5sp
92ES5sp's Avatar
Sounds like a vacuum leak.
Old 12-10-07, 07:02 AM
dundfaukus
dundfaukus's Avatar
If it were a vacuum leak then the car would idle much higher, car idles just like normal at 900-1000rpm...
Old 12-10-07, 03:36 PM
BadViper22
BadViper22's Avatar
If your Intake is cracked at all and there is a vacuum leak then you would have an idle around 500 rpms...
Old 12-10-07, 06:06 PM
92ES5sp
92ES5sp's Avatar
Smile
No. Normal idle speed is 750 with an automatic. If there is a vacuum leak the rpms will jump up and down.
Old 12-10-07, 07:32 PM
llcoolpass
llcoolpass's Avatar
From general automitve stance, I agree with the intake tubing leak hypothesis. The guys who posted before me probably know more about hte common problems with this car than I do since I'm new here. I would tell you the fuel hypothesis was also good, too.
Old 12-10-07, 08:14 PM
Rollin'ES3
Rollin'ES3's Avatar
If its only doing it on a hill. Id have to guess a fuel related problem. Possibly from the fuel pump or something.
Old 12-10-07, 09:41 PM
dundfaukus
dundfaukus's Avatar
Well thats what I mean, it idles what it normally does. I've ran cars with vacuum leaks and it is not this bad. If I'm going up hill, the car is jerking like a giant mechanical dog trying to hump the road in front of it.
nawilliams
05-13-12 04:40 PM
garrett
GS - 1st Gen (1993-1997)
05-01-12 12:53 AM
bbkbadboy
Performance & Maintenance
04-23-10 07:39 AM
twentyone
Performance
04-18-07 07:43 AM
bigguppy
08-09-04 09:51 PM
Quick Reply: Car shuts off on inclines...
