Help with rim fitting
Old 09-30-07, 11:44 AM
1994-ES300
1994-ES300's Avatar
Default Help with rim fitting
Can someone tell me if this size wheel will fit my 94 ES300?
17x7.5", 42 offset. Tires are 215/50R17.
I am hoping NOT to use any spacers. If you think I need spacers, what size?
I know the center bore of my AM rims is 66.10mm. So hub rings of ID 60.10 OD66.10mm are required. But is the offset that I am not sure about.
Also, can I have a staggered look by putting 255/45/17 in the back??
I know this is a FWD car....just wondering
Cary
Thanks
Old 09-30-07, 11:47 AM
Choas
Choas's Avatar
I don't think you will need a spacer and if you do it will be a small on in the rear. About the tires trust me i've tried it it does not work at all and I ended losing about 200 bucks on the experiment.
Old 09-30-07, 11:54 AM
1994-ES300
1994-ES300's Avatar
Default tires
But you think a staggered setup is ok? Because this is a FWD car will it not affect anything?
If you think it's ok with a staggered setup, what's the thickest tires you can go in the rear on a 17"?
thanks.
Old 09-30-07, 01:22 PM
Choas
Choas's Avatar
I don't notice a difference on mine with staggered rims for better or for worse. Honestly its really a waste do do it but if you insist you can go with 225/50/17's in the rear
bigboy0723
06-03-15 07:02 PM
fj40ih8mud
03-12-13 07:02 PM
brad11140
SC- 1st Gen (1992-2000)
01-05-11 03:04 PM
kingbigs11
03-08-10 07:24 PM
boxbrownie
RX - 1st Gen (1999-2003)
01-18-08 09:24 AM
Quick Reply: Help with rim fitting
