Are my struts need to replaced?
Old 05-28-07, 11:02 AM
99lexus
99lexus's Avatar
Default Are my struts need to replaced?
Hi,
I just replace my 2 front strut mounts. When working in there, I checked my struts: There is no leak. The ride still OK. The only problem is when press the struts all the way down ( compress it. ) It takes a long time, a bout a minute, for the strut return to it normal position. Is that indicate that the struts need to replaced?
The ride still OK now ( or I get used to it? ) but if it indicate that the struts are worn out, replace it now will save me another alignment cost.
Thaks,
Old 05-28-07, 03:10 PM
GrahamHill
GrahamHill's Avatar
I just trounce on each corner of my vehicles to make the car bounce. If the shock/strut is bad it will keep on bouncing after you stop trouncing on it. A good shock/strut will rebound back up and stop when you stop.
PDXLex
21
12-01-22 09:45 AM
energie8
08-12-15 05:47 PM
RVamiri
Suspension and Brakes
12
06-18-12 11:47 AM
850Lexus
01-17-12 10:38 AM
LC1338
01-06-07 07:42 AM
Quick Reply: Are my struts need to replaced?
