ES300: Replacing Cluster Backlighting Bulbs
Old 11-29-13, 01:15 PM
  #196
Steves330
Steves330's Avatar
Thumbs up New LED Dash
Lexucan,
Another awesome and easy DIY fix. Mine looked your old look and now looks great! Thanks!
Attached Thumbnails ES300: Replacing Cluster Backlighting Bulbs-led-dash-light-fix.jpg
Old 01-23-14, 12:45 AM
  #197
gtstcactus
gtstcactus's Avatar
My needles have died, so I thought if I'm going to pull the cluster out I might as well replace all the lighting while I'm at it....
I'm going to use green LED's - I hope these ones on Ebay will do the trick - http://www.ebay.com/itm/T10-192-194-168-GREEN-LED-interior-speedometer-indicator-license-plate-light-/231130704152?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ALexus%7CModel%3AES300&hash=item35d076a918
I'm probably going to pull the needles from a cluster at a wreckers and send them to the same seller if they will let me just send the needles and repair them... I'm not sure if I want blue or red needles...
When I get the needles back I'll pull my cluster out and do the switch, and replace the backlighting bulbs...
Old 01-23-14, 01:45 AM
  #198
gtstcactus
gtstcactus's Avatar
any idea what sort of LEDs the chap in this video has used???
I cant find the remote controlled color changing ones with the T1 3/4 base..
Old 02-22-14, 05:54 AM
  #199
LudeNsoL
LudeNsoL's Avatar
I did this last night and I can't seem to make any of them work. I tested each LED individually and also made sure of the polarity but once installed none light up. Any suggestions?
Old 02-22-14, 07:34 AM
  #200
Lexucan
Lexucanafer
Lexucan's Avatar
Check your ribbon cable and wiring harness connections. Something is preventing a proper electrical connection to the circuit board.
Old 02-22-14, 07:47 AM
  #201
LudeNsoL
LudeNsoL's Avatar
Thanks for the quick response and I checked everything. Its all connected all the way screws are snug. Still nothing. And now the tach spring became unsprung and needle does not move. I guess I will now need a new cluster unless there is a way to respiring the coil. ?
Old 02-22-14, 08:09 AM
  #202
Lexucan
Lexucanafer
Lexucan's Avatar
You obviously have more serious issues with your cluster than just dead LEDs
That is the risk in working with electronic parts that are two decades old. Wires and plastic can become brittle and break. I'm not sure how to deal with an unsprung tach. You may need to find a replacement for it.
As for the backlighting issue, something is clearly still not properly reconnected.
Old 02-22-14, 10:31 AM
  #203
TaninAuto
Sponsor
TaninAuto's Avatar
We can repair your cluster. Once the spring is messed up there is no going back. We can replace the motor assembly. We also fully rebuild the ES clusters with leds or whatever you need.
Www.taninautoelectronix.com
Old 10-31-14, 04:01 PM
  #204
monrovia72
monrovia72's Avatar
Default Question
I realize that this forum is pretty old, but I'm hoping to get some help. I followed the forum word for word pretty much and replaced my backlights from that gross urine color. When I went into the situation the right-hand side of my dash was pretty much completely dark. Now, after plugging everything back in, it's a lot prettier, but that right hand side is still pretty dark. Could this be a wiring problem? Or should I go back in on the right and switch the polarity of the bulbs, 'cause it's plausible that I put them in, on the wrong polarity. Any suggestions?
Old 10-31-14, 04:02 PM
  #205
TaninAuto
Sponsor
TaninAuto's Avatar
Component failure on the circuit board
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
Old 10-31-14, 04:26 PM
  #206
Lexucan
Lexucanafer
Lexucan's Avatar
It's quite possible that one or more of your bulb polarities are wrong. I would recheck them before assuming that there is another problem.
Old 10-31-14, 04:30 PM
  #207
Lexucan
Lexucanafer
Lexucan's Avatar
You wish...
Old 11-02-14, 04:23 PM
  #208
TaninAuto
Sponsor
TaninAuto's Avatar
We have clusters sent in all the time with this issue. If he didn't have half of his lighting before and still does not have lighting then it is a component failure on the main board.
The left and right side of the cluster backlighting is powered by two different circuits and one side failure is common.
__________________
262-456-4147
Old 11-12-14, 11:51 AM
  #209
missjez
missjez's Avatar
So a few of my red needles are out and or flickering. My mileage/trip is also out. Will these instructions fix the mileage/odometer readings?
Old 11-12-14, 12:10 PM
  #210
TaninAuto
Sponsor
TaninAuto's Avatar
No. Odometer display not showing up is either a main board issue or the actual odometer display assembly.
__________________
262-456-4147
Quick Reply: ES300: Replacing Cluster Backlighting Bulbs
