'97 ES300 trans oil change? Synthetic?
My 70k mile ES300 needs some new transmission fluid. Has anyone used Redline D4ATF in their '97-'02 ES300?
Does the transmission and transaxle share the same fluid or are they separate drains and fills? How often does the ATF pan filter need to be changed?
Thanks
Thanks
I found this info posted by Phoenix:
My car is for sure a 1997 with the 4spd auto so I guess Dexron III or the ame spec synthetic Redline should do the trick Do all the models that require TT-IV cars say so on the dipstick?
Another Phoenix quote:
What fluid does the diff take?
TT-IV didn't come unto play util the 99's U140E transmission.
Dexron is specified for all the A54X family of transmissions (i.e. transverse v6 camry platforms '87-98).
You also will want to drain and refill the differential. It's nothing imperative, most cars never get the differential fluid changed, but it is time to do so. It holds 1.7quarts, but normally only drains out a quart. Have two, just in case.
Super Moderator
I am not sure if your ES300 trannies are similar to the ones on the RX300, though the 1MZFE engine is certainly similar.
The plug on the right is for the tranny itself, but the one on the left belongs to the front differential. You want to drain both of then.
Both use ATF. You can fill them up though the ATF dipstick. Don't worry, the ATF you pour in via that route will go in not only into the tranny itself, but also trickle over into the front differential (they are connected).
Super Moderator
That fluid in the front differential really can get bad if not changed since it does not circulate as well.
We actually found a fill plug on the back side of the transmission for front differential (very hard to get to).
Are most people using a good Dexron III synthetic for the 1997 ESs?
Super Moderator
By chance, has anybody here tried Amsoil ATF in their ES?
We have had people use it in their RXs.
I was wondering when someone was going to mention this.. .....I have the Amsoil ATF in right now in my ES330 and there is no transmission lag to talk about yet. Its also good to overfill the transmission case by a bit.
Super Moderator
I wish they sold Amsoil down here as it is impossible to import with a hefty tax and a lot of paperwork/red tape. When I get back to the U.S.
