96' ES 300 Key broke with keyless entry..
Old 01-10-07, 09:33 PM
Push
Push's Avatar
Default 96' ES 300 Key broke with keyless entry..
Well after 11 years, my master key cracked... The battery and the little rubber part for the keyless is lost... The key itself is fine, but the black Lexus part is cracked and needs to be replaced... What kind I do to get my Keyless to work again? Get another key? Fix the key I have currently with glue? I am kind of stumped... Thanks for your help!
Old 01-12-07, 04:15 PM
djdoughboy
djdoughboy's Avatar
Hey there! Hopefully I can answer your question. The 95-96 keyless system is a system that can be user re-programed unlike the 92-94 rom chip keyless system. What you will need to do is purchase a new key with transmitter on it. To program the new key:
Sit in the driver's seat and lock all the doors.
Unlock and open the driver's door.
Insert the key into the ignition and remove it (don't turn it...just remove it).
Using the MANUAL lock switch on the driver's door, lock and unlock the door 5 times.
Close the door.
Open the door.
Lock and unlock the driver's door 5 times (I'm almost certain you use the MANUAL lock switch again, but if this sequence fails to work, try again with the power switch).
Insert the key into the ignition and turn it to the "ON" position.
Remove the key.
The driver's door will now lock and unlock itself one time.
Press and hold the "LOCK" button on the key fob for at least 1 second.
Close the driver's door.
Open the driver's door.
Press and hold the "LOCK" button on the key fob for at least one second.
Press and hold the "LOCK" button on the key fob. The door will lock.
Press and hold the "LOCK" button on the key fob again. The door will unlock.
hope that helps
Old 01-12-07, 07:38 PM
Push
Push's Avatar
I LOVE YOU... if it works...
Old 01-13-07, 05:59 PM
3000's Avatar
Um.... go to Lexus dealer and ask... I mean they give out free battery for the key and install it themself for free, but I don't know about the fixing the plastic part for free...
marty99
10-04-13 06:13 AM
OT0814
11-04-10 04:56 PM
habdelr
GS - 1st Gen (1993-1997)
04-20-09 09:08 PM
kino1161OL
19
11-07-08 02:12 PM
Quick Reply: 96' ES 300 Key broke with keyless entry..
