ES300 W/TSX retrofit pics..
Old 01-03-07, 11:05 PM
draikonz
draikonz's Avatar
wOW....it looks very nice ..GOOD JOP ON THE RETROFIT!
Old 01-03-07, 11:11 PM
LXMN
LXMN's Avatar
Thanks for all the positive comments guys. I have started the other headlight and am almost done with it. I have to clear up the plastic lenses due to the fact that they are used and very pitted with some cloudiness. I might be able to install on the car on Monday ( my one day off of work) if the weather agrees. A bit chilly outside in Iowa. I will post more pics when they are installed.
Old 01-03-07, 11:48 PM
rob96826
rob96826's Avatar
Originally Posted by LXMN
I just finished one side of my headlights for my retrofit project. It is my first time doing this so critique lightly please. Here are some pics...
is that an mdx bezel on the projector???
Old 01-04-07, 12:06 AM
LXMN
LXMN's Avatar
Yes it is. I liked the way they look so that is why I chose to go with them. I had to grind down the inner ring that seats over the projector lens in order for it to sit right. Then used JB kwik weld to secure it in place.
Old 01-05-07, 06:12 AM
Seize
Loves Snickerdoodles!
Seize's Avatar
Very nice DIY!
Old 01-05-07, 12:11 PM
chrispy
chrispy's Avatar
did you wetsand the lenses? i did that to mine and it turned out really well. make sure you wear gloves. even at the very fine grits, i still sanded away my skin.
Old 01-05-07, 12:24 PM
LXMN
LXMN's Avatar
I did wetsand with 1500 grit, then used Meguiar's Plastx. They are very clean looking with no light on, but when lit up, I can still see small hazy scratches where the light projects thru. They are not crystal clear. I can't expect them to look perfect, right?
Any suggestions on this?
Old 01-05-07, 12:35 PM
chrispy
chrispy's Avatar
after the 1500 grit, finish it off with the 2000 grit. make sure you sand vertically, then horizontally. alternate a few times. avoid doing circular motions. i used 3m rubbing compound after the 2000 grit, then finished it off with the plastx polish.
i'll post up some pics after i wash my car this weekend.
Old 01-05-07, 12:49 PM
LXMN
LXMN's Avatar
Look forward to it. Show a pic with the lights on without glare if possible.
Old 01-06-07, 01:22 PM
LXMN
LXMN's Avatar
I finished off the second light. Went out to the store and bought some 2000 grit sandpaper and wetsanded both lenses again. Then buffed them out with some 3M rubbing compound and finished up with PlastiX. I am satisfied with the outcome. They are not 100% brand new looking. I would say 90%. And that would equal an A-.
The picture is kinda like a before and after shot. One wetsanded and the other buffed out.
I have Monday off, so the install will happen then. (Fingers crossed)
Attached Thumbnails ES300 W/TSX retrofit pics..-100_0822-medium-.jpg
Old 01-06-07, 01:58 PM
chrispy
chrispy's Avatar
WOW they look brand new. great job. see? the 2000 grit does make a difference.
Old 01-06-07, 02:03 PM
chrispy
chrispy's Avatar
here are some not so good pics that my friend took on new years eve. there is some glare and i linked the pictures because they're big.
http://i14.tinypic.com/2la79dv.jpg
http://i16.tinypic.com/2vkcbjs.jpg
http://i16.tinypic.com/4bzl0ev.jpg
i got rid of all the scratches but i couldn't get out the small cracks and pits. they look pretty good for 10 year old headlights though.
Old 01-08-07, 04:00 PM
LXMN
LXMN's Avatar
Lights are installed on the car.
Attached Thumbnails ES300 W/TSX retrofit pics..-100_0825-small-.jpg
Old 01-08-07, 04:05 PM
LXMN
LXMN's Avatar
Night shot. Showed the foglights as a comparison look. A noticeable difference in color.
Attached Thumbnails ES300 W/TSX retrofit pics..-100_0827-small-.jpg
Old 01-08-07, 04:08 PM
LXMN
LXMN's Avatar
Car is sloped so that is why the light is at an angle. Only way I could get the wall shot on the side of the house.
Attached Thumbnails ES300 W/TSX retrofit pics..-100_0829-small-.jpg
Quick Reply: ES300 W/TSX retrofit pics..
