Air Conditioner Flood
Old 07-22-06, 07:44 PM
zzzzkev
zzzzkev's Avatar
Default Air Conditioner Flood
Here's one I've not experienced in 35+ years of automobile ownership.
1997 ES300 with 148,000 miles, excellently maintained. Live in MD. Lately it's been VERY HOT (95+F) & very humid. When using the a/c, the passenger compartment floor gets SOAKED with water. SOPPING WET!!! The front passenger side as well gets wet. This is not a "weatherstripping" leak (my first thoughts).
Tonight, with family in car on a hot and humid evening, drove the car and used the a/c in the rain to dehumidify. While the a/c is in use, the floor of the passenger compartment becomes a small low pressure system (meteorological metaphor) and several towels must be used to soak up the water after a 15-25 mile drive when we get home. Not good at all.
We have identified that the cause is the a/c when we use it. This is obviously a problem! Has anybody experienced this, and what is the cause? Is this something I can repair myself? Need help before the bottom falls out!!! I have an OBD II code reader and get a "NO CODES" when reading the on-board computer. I am also extremely capable of performing car repairs as I do most of the maintanance myself. Help!!!!!
Old 07-22-06, 11:09 PM
Parke10
Parke10's Avatar
the only thing i could think of would be the (i think its called) condensation drain hose has poped off or is pluged or sumthing?
Old 07-23-06, 05:34 AM
amf1932
amf1932's Avatar
The evaporator drain is clogged. You can sometimes unclog it by getting under the car and running a snake up the drain tube.
Old 07-31-06, 05:24 PM
zzzzkev
zzzzkev's Avatar
Red face Air Conditioner Flood: RESOLVED
Thanks for the tip on the evaporator drain plug. I changed the oil and filter, checked the tire pressure, and got under the car to complete the prep for my wife's trip to Pittsburgh. Clipped a coat hanger and measured off and marked one inch increments. I inserted it into the drain ~8in or so, and Wholaaa! At first a trickle. I teased it bit more and there must have been a 20 second flood of water that came rushing out. I estimate it was at least a gallon!
Needless to say, problem resolved. Trip went well and the a/c works great (again). My wife thanked me too (but this is not the forum) Thanks!!!
Old 08-07-06, 02:52 PM
703's Avatar
Awesome, I have the same problem with my ES300. Can you tell me exactly where this drain is and what it looks like?
Cheers.
Old 08-07-06, 07:53 PM
Tammy
Tammy's Avatar
A rubber tube or hose about a half inch in diameter. Accessed from the right side, behind and inside the right front wheel. It protrudes out from the firewall.
Old 08-13-06, 10:25 PM
703's Avatar
Thanks, I still have trouble finding it looking down from an open hood.
Do I have to jack up the car and look underneath the firewall to find it?
Old 08-19-06, 01:53 AM
703's Avatar
Could you insert it more than 8 Inch? I tried on mine today and couldn't insert any further at about twice the length of the protuding hose.
draco
11-19-23 04:40 PM
blkvader
09-13-21 08:05 AM
chiro
02-01-11 03:49 AM
bwesky
05-26-10 04:37 AM
Jcham
09-06-09 05:20 PM
Quick Reply: Air Conditioner Flood
