Remove cigarette lighter
Old 05-22-06, 06:57 PM
ronolexus
ronolexus's Avatar
Default Remove cigarette lighter
Hi i was wondering on how to remove the cigarette lighter on my 1996 es 300. A nice and well discriptive instruction would be nice. Thanks in advance
Old 05-23-06, 03:53 PM
ronolexus
ronolexus's Avatar
does anyone know. I really need to remove it fast
Old 05-23-06, 04:06 PM
element51
element51's Avatar
just follow the first few steps, improvise a little bit to remove cigarette lighter assembly and you should be good.
https://www.clublexus.com/forums/sho...d.php?t=158636
why did you have to remove the cig lighter, anyway?
Old 05-23-06, 05:18 PM
ronolexus
ronolexus's Avatar
i have to replace the cigarette lighter because it just stop working. My dad plug in an invertor and this huming sound started from the invertor. After i unplug the invertor the cigarette lighter hasnt work ever since. I check one fuse and it still look good, so im pretty sure it the cigarette lighter itself.
Old 05-23-06, 05:30 PM
ronolexus
ronolexus's Avatar
okay does anyone know how to "pop out" the wood grain around the shifter? Im scared that i might break it or crack it. Thanks in advance
Old 05-23-06, 07:43 PM
allerton
allerton's Avatar
https://www.clublexus.com/forums/sho...hreadid=143264
Old 05-24-06, 08:54 AM
element51
element51's Avatar
read the comments on that fitst post sent you bro come on.
on the second page, it says "Sure. You need to take a flathead [screwdriver] and pop the woodgrain out. The best place would be in the dip underneath the end of the emergency brake. Just stick in the flathead and lift directly up."
Old 05-24-06, 10:15 PM
Lexbox
Lexbox's Avatar
I thought this guide would come in handy. Score one for me!
Old 05-25-06, 09:54 AM
3000's Avatar
I just pulled it out with some pliers.
Old 05-29-06, 09:54 AM
ronolexus
ronolexus's Avatar
okay thank you for all your help and response but i have another question how do i remove the cigarette lighter itself? Can i buy a universal cigarette lighter to replace it or do i have to get one from lexus
Old 04-28-10, 11:32 AM
mwe
mwe's Avatar
did you ever figure out how to pull the socket itself out?
Old 04-29-10, 06:55 PM
LexusScorp
LexusScorp's Avatar
If I'm looking at this correctly...this thread started in 2006...
Old 05-19-14, 04:44 AM
ripready
ripready's Avatar
I just did it. You remove the shift plate surround.
Remove the black housing around the lighter (there are two clips holding it under the plug)
If you look inside the lighter, there are two green tabs. You need to get a small screwdriver in between the metal surround and the green tabs. This will release the metal lining. You need to do this from the wiring side of the lighter.
Push the metal lining of the lighter through to release
sereousl
07-21-14 05:14 AM
Nexevious
SC- 1st Gen (1992-2000)
12
06-06-14 07:32 PM
LexusPia
07-18-12 10:02 AM
jjgonza
03-23-06 03:46 PM
Quick Reply: Remove cigarette lighter
