Hard to replace alternator? 1994 ES300
Old 05-20-06, 01:10 PM
Pogo
Pogo's Avatar
Default Hard to replace alternator? 1994 ES300
I'm not sure if my alternator is going, but in case it is:
How much should a good one cost?
How hard would it be to install myself?
(Ability = Bolt-off, bolt -on; moderate troubleshooting; or need *very* specific manual/instructions)
How much to have it done by good mechanic? There's a non-dealer who specializes in Lexus in town.
Thanks in advance
Old 05-20-06, 02:55 PM
Pheonix
Pheonix's Avatar
Cool
14mm bolt, 12mm bolt, 10mm bolt. You'll want a deep well 14mm socket & a normal 12mm socket.
It's bolt on / bolt off once you get to it. When installing, get the belt on the pulley, put the 14mm bolt in enough to hold it (not fully tight), pull the alternator up pretty hefty with your wratchet on the 12mm nut & tightne it - then tighten the 14mm nut.
Really all you need to know. Nothing about it is difficult.
alternators varry depending on what kind it is.
Old 05-21-06, 09:10 AM
mcelligott
mcelligott's Avatar
I would look into getting a remanufactured unit. I saved about 50 bucks by buying one and it works great. should run you around 100 bucks. Make sure you get a good quality belt like a gatorback, youll expect to pay about 20 for the belt.
Old 05-22-06, 08:47 AM
sk72
sk72's Avatar
Post
Thanks in advance
I would suggest you bring it to Autozone for a check before replacing... it's a free check anyways ... Good Luck... with your DIY...
Old 05-22-06, 01:43 PM
Lexbox
Lexbox's Avatar
Swapping out the alternator is a piece of cake. If you want a little more power out of your alternator for the stereo and stuff, search around for the Highlander alternator swap. You can pick up one for cheap at the junkyard.
Old 05-22-06, 04:57 PM
kdogg
kdogg's Avatar
Thanks in advance
Pogo, I have a Highlander alternator in perfect condition, about 30k miles if you want to buy one.
OldLs400
07-15-18 09:51 AM
Harrellsm
RX - 1st Gen (1999-2003)
09-20-17 04:56 PM
Arden
04-24-17 07:48 PM
Pzindy
07-20-15 08:20 PM
SANDSTONE
Performance & Maintenance
07-03-14 02:08 PM
Quick Reply: Hard to replace alternator? 1994 ES300
