1993 ES300 H.O Alt
1993 ES300 H.O Alt
im running a JBL 1200.1 which can draw a maximum of 114 amps. Obviously the stock one restricts it so ya im looking for a HO ALT. Heres what I found http://cgi.ebay.com/ebaymotors/93-Le...QQcmdZViewItem. What do you guys think? suggestions plz.
I wouldn't touch it, but you can take the plunge if you want too. The seller/reseller is completely unknown the Camry, and ES/Windom forum community.
Buy the 130amp Highlander alt, or get yours re-wound to whatever spec you want.
And if you play that amp hard at all it's going to be alot more than 114amps.
My 1200.1 @ 1 ohm driving my two kicker 10" L7's was continually blowing fuses until I used a 125amp main fuse. Then again I charge at 13.8. At any rate... You need to fuse that thing for 125amps on the main line just to protect the amp from shorting in the wiring. Notice the amp itself is fused for 120amps.
noyz25
05-25-11 04:04 PM
leany
03-29-05 08:14 AM
