Flasher location
you are talking about the lights, right? turn on the flasher and look under the dash to see if you can hear where the noise is coming from. There has to be a relay or something you can hear, I may be wrong. Or there might be a cheap way by going to autozone and looking for the auto manual of the same year camry of your car and see if it can locate the flasher. I'm not sure but you might also want to check under the hood. Most relay or fuse boxes should tell you which relay or fuse it is Just check those.
