Car Grounding: How To:
Whats up guys, i was wonder about making a grounding kit for my 95 ES. I have a bunch of 4ga amplifier wire and about a foot of 0ga. I was curious how to make the grounding kit. Like i said i have the wiring and the terminals but i have no clue what it needs to be connected to. Ill prob end up connecting the 0ga from the ground to the body but after that i have no clue. Do the other wired connect to the engine somewhere? tranny somewhere? atlernator?
What kind of overall gains will i gain from this.......someone told me it should improve the idoling, throttle response and the overall electrical circuitry to the car.
input please,
Brennan
input please,
Brennan
Super Moderator
input please,
Brennan
input please,
Brennan
I have the Sun Hypervoltage Kit and the Sun Hypergrounding Kit. However, previously I made my own system with Monster Cable and several other gauge wires. All of my wires go off of the negative battery terminal.
input please,
Brennan
input please,
Brennan
throttle response
It's going to give you a tiny bit less diming if you're driving a small-medium sized amp.
Basically... It's something everyone with a system should do.
1) Alternator to battery
2) Battery to chassis
3) Chassis to engine
Lexbox, engine to chassis & engine to firewall are the same thing. It's redundant. The engines themselves have multiple connections to the chassis stock. On average, 3-4, 8ga copper wires. Not including mechanical connections.
Originally Posted by Lexbox
Personally, I used all 0-gauge wire when I did it to my ES. It is referred to as the big three and they are as follows: Battery to chasis, chasis to engine block, engine block to firewall. Dont forget to ground everything to a bare metal surface, dont let the paint get in the way. If you have a meter, check continuity if you are unsure.
