Go Back   Club Lexus Forums > Lexus Model Forums > ES Models > ES300 and ES330
Sign in using an external account
Register Forgot Password?
Fixing the Radio LCD
Thread Tools Search this Thread Display Modes
Old 04-20-07, 11:33 PM   #16
lexsterES
Trader Score: (0)
lexsterES's Avatar
Damn how did I miss this post??? Awesome write up woogie! This is definitely my next upgrade!!! You saved me a big headache on figuring out what aftermarket system I was going to get, this should set me back a few more years.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
lexsterES is offline   Reply With Quote
Old 04-25-07, 02:36 AM   #17
Jimbo88
Trader Score: (0)
Hi everyone,
I drive a 95 ES300. The lights behind my LCD/Climate control dash went out. There was a click like you hear when you turn on the headlights. Now the radio and air doesn't work and only the clock is displayed. Would a bulb replacement fix this most of the time or is there another possible issue?
If that is the problem, would the bulbs be visible from removing the radio in this tutorial, and where can I find the parts?
I checked out the bulb thread for the 2000 ES version, but since this is all new to me, I don't know the differences.
Thanks for the tutorial and your time.
Jimbo88 is offline   Reply With Quote
Old 07-26-07, 02:52 PM   #18
zzzzkev
Trader Score: (0)
Excellent write up! This will be least expensive alternative to totally replacing the radio (which Lexus did once before under warranty). I have this to do next on my list after the stupid seat belt replacement issue.
zzzzkev is offline   Reply With Quote
Old 09-26-07, 09:53 PM   #19
BDSL
Trader Score: (0)
Hey guys, 1st post but I have been reading for a while.
Which is the correct part number for my 97 ES300?
CWM4931 per http://www.wikihow.com/Replace-the-Radio's-LCD-in-a-Lexus
or
CWM4319 per this thread?
Both part numbers exist in the Pioneer webpage.
BDSL is offline   Reply With Quote
Old 09-27-07, 04:40 PM   #20
BDSL
Trader Score: (0)
Somebody, please clarify the correct P/N.
Old 09-29-07, 07:26 AM   #21
BDSL
Trader Score: (0)
Unbelievable...one of the threads with the most views and yet no one knows the answer.
Old 09-29-07, 07:40 AM   #22
Sash
Trader Score: (0)
Sash's Avatar
Send a message via AIM to Sash
CWM4319
messagetooshort...
Sash is offline   Reply With Quote
Old 09-29-07, 12:08 PM   #23
BDSL
Trader Score: (0)
Thanks. The reason I asked because I am located in Canada and the Pioneer phone number does NOT work for Canadians. It told me that the service is not available. I tried a few other places but none can verify which is the correct part number and there is no return policy. So I just want to be 100% sure before I order.
Old 10-01-07, 07:36 PM   #24
harrywat
Trader Score: (0)
Excellent write up Woogie. I put it to use today, got everything apart on the bench and the part on order, it was $113.23 delivered.
everything went very smooth, in fact I did the R&R twice. The PO had a spare package from a parts yard, so I installed it only to find out it had the same problem. I put the original back in and will repair the yard unit.
Had you not gone to the trouble to provide a great DIY show-N-tell, I may never had gotten this done.
Many thanks
Harry
harrywat is offline   Reply With Quote
Old 10-27-07, 01:27 PM   #25
zoomzoom
Trader Score: (0)
Default 97 ES300 Radio CNP4092 Circuit board part number
The info on the ES300 LCD replacement was very helpful.
I have a couple of the radio control bulbs that burned out, and there was a note that could get the bulbs at Radio Shack T1 blub. I tried and apparently they no longer carry the blubs.
When I put everything back together... All the radio control lights to all the buttons no longer light up. The circuit board with the solder bulbs read CNP4092, and when I check Pioneer website, I can not find this board.
By any chance if anyone know the part number for the board w/the blubs or if they sell the replacement board w/the blubs.
Thanks in advance.
zoomzoom is offline   Reply With Quote
Old 10-27-07, 04:48 PM   #26
Lexus4You
Trader Score: (0)
Lexus4You's Avatar
i have my original stock lexus radio up for grabs if anyone is intrested let me know... from a 93 lexus.. in great shape.. anyways.. how can i fix my climate control lcd.... right by the clock it went really dark... its pissin me off...
Lexus4You is offline   Reply With Quote
Old 10-28-07, 05:49 AM   #27
Choas
Trader Score: (0)
Choas's Avatar
^Cough check out the sticky on the top
__________________
Sig. by drpepper
Choas is offline   Reply With Quote
Old 10-28-07, 05:53 AM   #28
Choas
Trader Score: (0)
Choas's Avatar
About this T1 bulb does anyone have any info on it. Is it an led and if so what is the volts/amps/mcd of the led. I work at the shack and most likely it was replaced with something similar. Also they are heavily increasing their parts line so you might see a lot of stuff like this come back if it was disco
__________________
Sig. by drpepper
Old 01-16-08, 04:10 PM   #29
searay
Trader Score: (0)
Nice writeup. I have to replace mine as well. 98 ES300 Is the LCD Part # CWM4319 for a 98 also???
searay is offline   Reply With Quote
Old 06-06-08, 07:41 PM   #30
dm124ES
Trader Score: (0)
Default Another satisfied DIY'er
Yes, the part number for a 1998 ES is CWM4319. I JUST NOW completed the install and mine looked almost exactly like the one Woogie had... burned out in the same place. The whole process took an hour and a half. It would have been a little less, but the A/C vent and clock piece was a biznatch trying to get off. That burnt about 20 minutes. I brought the radio inside to change the display and put everything back together with the radio and then reinstalled in about 10 minutes. The hardest part is obviously getting to the radio itself. The part from Pioneer was $126.xx and arrived in one and a half days... ordered at 10:30 Wednesday night, arrived 11:00 am Friday morning. They should have it to you quick!
I'm a DIY rookie when it comes to cars, so if I can do it, you can! The display looks so much more clear and the display has blacker digits. SOOOO glad that smudged out area is gone forever. TURN IT UP!!!
Thanks Woog!!
__________________
I've had a few cars, but I love my Lexus.
dm124ES is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Friends' Ride Ice350 ES300 and ES330 12 01-09-09 12:10 PM
5Zigen bolt on axle-back exhaust 3rd Gen Maxx941 ES300 and ES330 11 10-16-08 01:21 AM
ES Annoyances 2nd Gen tuan92129 ES300 and ES330 15 10-30-07 06:21 AM
Guess what...I'm finally dropped!!!!!! tiguy99 ES300 and ES330 12 10-24-06 11:58 AM
Me latest HID retrofit project (underway) tiguy99 Lighting 36 04-23-06 01:22 PM
Tags
change, cwm4319, cwm4931, dark, es300, fix, fixing, lcd, lexus, lights, ls400, pioneer, radio, replacements, screen
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
