How to Modify 2DIN Radio to accept 2.5DIN - Pictorial
Old 04-12-05, 06:49 PM
Lexbox
Lexbox's Avatar
Default How to Modify 2DIN Radio to accept 2.5DIN - Pictorial
I finally decided to convert the 2DIN stock radio bracket to accept a 2.5DIN setup. I have a 1 DIN Fold-Out LCD, a 1DIN Eclipse radio, and a 1/2 DIN EQ. I previously removed the cupholder to house the EQ and I think its about time to correct it. This is for anyone that has packed the dash full of goodies like myself. I threw in a LED relocate job on the EQ as a bonus! So here goes.
For those that do not know what a DIN is. 1 DIN is the size of a standard cd player. 2 DIN is twice as large. You can also have a 1.5 DIN or 2.5 DIN as is the case here. You will notice in the background of the first pic that I have my TV, Cd player, and EQ on top of each other.
1. Remove Radio
a. Pop Dash Vent.
b. Pop shifter woodgrain.
c. Remove cupholder/ashtray assembly. (4 phillips)
d. Remove two 8mm bolts from vent hole and two more near the ashtray screws.
2. Remove the units from the stock radio brakects.
Attached Thumbnails How to Modify 2DIN Radio to accept 2.5DIN - Pictorial-din-003-small-.jpg
Old 04-12-05, 06:51 PM
Lexbox
Lexbox's Avatar
Default Stock bracket + Hammer = Fun
Here is the Left flattened bracket.
*Note*
For some crazy reason the Left and Right brackets are not the same before they are flattened so they definitely werent afterwards. Because of this you will find I had to mount each side differently.
Attached Thumbnails How to Modify 2DIN Radio to accept 2.5DIN - Pictorial-din-011-small-.jpg
Old 04-12-05, 06:56 PM
Lexbox
Lexbox's Avatar
The next bit of work will be specific to the 1/2 DIN unit or the way you choose to stack your various equipment. Mark out a rough template and get to work.
3. The right bracket, when flattened as directed, will actually hang down and block the reinstallation of the radio. So I whipped out the trusty jigsaw and went to work. I know its crooked. You do NOT need to cut off anymore than what I cut to work around the blockage issue. So dont do that.
Attached Thumbnails How to Modify 2DIN Radio to accept 2.5DIN - Pictorial-din-059-small-.jpg
Old 04-12-05, 07:02 PM
Lexbox
Lexbox's Avatar
Default :Victory Dance:
When everything is buttoned back up it should look something like this. Minus the Smartphone of course, and yes that is the Firefox skin.
4. Pop the radio back in making sure not to overtighten the 8mm bolts because you WILL snap the head off. Cupholder goes back in before the grain around the shifter.
Attached Thumbnails How to Modify 2DIN Radio to accept 2.5DIN - Pictorial-din-055-small-.jpg
Old 04-12-05, 07:09 PM
Lexbox
Lexbox's Avatar
Default And Now......For the Bonus
The AudioControl Four.1 features a line driver which basically boosts the 4V (if your lucky) up to a maximum of 13v. Well, thats alot of juice, so AudioControl put a Overvolt indicator LED visible from only the top of the unit which we just covered up. Not anymore. The first picture highlights the problem.
Attached Thumbnails How to Modify 2DIN Radio to accept 2.5DIN - Pictorial-din-018-small-.jpg
Old 04-12-05, 07:13 PM
Lexbox
Lexbox's Avatar
Default Lets void the warranty and open her up
I do component level repair on laptops, amps, xbox's, cd players, and whatever else needs fixing. Be advised...Im not really sure if it voids the warranty but Im pretty sure. Here you will see the LED that has a protector to ensure it is not bent easily.
Attached Thumbnails How to Modify 2DIN Radio to accept 2.5DIN - Pictorial-din-028-small-.jpg
Old 04-12-05, 07:15 PM
Lexbox
Lexbox's Avatar
Default Adding the tail to relocate the LED to the front panel
Here is the tail I added. It looks alot easier if anyone is thinking this isnt easy.
*Added* Forgot to mention that removing the circuit board from the case will require you to remove the power button. Take something extremely small and get behind it. Force is NOT going to get it off, only a small wait while exerting minimal force from behind the ****.
Attached Thumbnails How to Modify 2DIN Radio to accept 2.5DIN - Pictorial-din-034-small-.jpg
Old 04-12-05, 07:18 PM
Lexbox
Lexbox's Avatar
Here is what the EQ looks like stock. We are gonna put the LED centered above the word Equalize.
Attached Thumbnails How to Modify 2DIN Radio to accept 2.5DIN - Pictorial-din-041-small-.jpg
Old 04-12-05, 07:22 PM
Lexbox
Lexbox's Avatar
I forgot what size hole I drilled but the new LED is much larger than the power indicator LED (red).
Its not centered because the bit slipped a tad. Too late now....oops
Attached Thumbnails How to Modify 2DIN Radio to accept 2.5DIN - Pictorial-din-045-small-.jpg
Old 04-12-05, 07:25 PM
Lexbox
Lexbox's Avatar
Default :drum roll:
And here it is...finally finished.
Attached Thumbnails How to Modify 2DIN Radio to accept 2.5DIN - Pictorial-din-071-small-.jpg
Old 04-12-05, 07:27 PM
Lexbox
Lexbox's Avatar
Default Night time shot
The camera's optical image stabilization doesnt work well when the flash is off. You get the idea though.
Attached Thumbnails How to Modify 2DIN Radio to accept 2.5DIN - Pictorial-din-072-small-.jpg
Old 04-12-05, 07:31 PM
Lexbox
Lexbox's Avatar
Thanks for waiting for me to finish the guide before anyone posted. Took me while to gather my thoughts between some of them. Hope you enjoy.
Coming up next is my How to Fix Cupholder Ejection - Pictorial. Tune in.
PM me for suggestions on Pictorials or what not. Im always needing to modify something or make something better.
Old 04-12-05, 07:46 PM
lexusk8
lexusk8's Avatar
Well you definitely took your time writing up your instructions, but most importantly they are clear and to the point. Excellent job putting up your DIY methods, and I enjoyed reading through them (esp. with pics included)
Old 04-12-05, 08:04 PM
DaveGS4
Forum Administrator
Administrator
DaveGS4's Avatar
Received 2,311 Likes on 1,410 Posts
Very nice writeup lexbox, thanks for taking the time to share
BTW< noticed the strategic CL business card in the pic You must have gotten your window stickers.
Old 04-12-05, 08:31 PM
juan01
juan01's Avatar
Interesting. Now you need to cover the sides up!
Quick Reply: How to Modify 2DIN Radio to accept 2.5DIN - Pictorial
