Old 12-16-14, 11:35 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
Fog lights switch Mod
Old 03-01-10, 11:18 PM
  #31
R1R
R1R's Avatar
Originally Posted by branddz
for a 98 es300, how would you connect it to the tail light fuse?
Just use a fuse tap. Why would you want to connect it to the tail light fuse? If you do it that way, you can only run the fog lights with the parking lights or low beams on. If you tap into the 12v accessory fuse, you can run the fog lights completely independent of everything. Very simple that way.
Old 08-30-11, 06:57 PM
  #32
scotholden
scotholden's Avatar
If anyone still reads this thread; i tried going about it today, but for the life of me could not get a quick disconnect to plug into the slot for prong 2. 3 & 4 went in without trouble. Ideas?
Thanks!
Old 09-13-11, 12:24 PM
  #33
jamodeo
jamodeo's Avatar
FYI bananags moved his page to here: http://bananags.grantham-internation...GS_DIY/FOGMOD/
-Joe
Old 07-28-13, 03:50 PM
  #34
imherenow
imherenow's Avatar
finally did it!! ..here the look i have been wanting for:
I had to thank speedkar9 for his help. Without his simple mod i never could have done it
Attached Thumbnails Fog lights switch Mod-dscf0368.jpg   Fog lights switch Mod-dscf0367.jpg   Fog lights switch Mod-dscf0401.jpg
Old 08-29-14, 06:44 PM
  #35
kevno6
kevno6's Avatar
Default Old Thread Revival
I bought a 2000 es300 a few months ago and did this mod and it works great for keeping the foglights on. My problem is that when I turn on headlights or they come on auto the fogs turn off, they are only on with drls. Is there something I am missing or is this normal I would love for them to be on with low beams also. Thanks from the Newbie
Old 08-31-14, 11:34 AM
  #36
lostape45
lostape45's Avatar
Can you specify which fuse you tapped into? Depending on the fuse, you may have tapped into one that has certain requirements for it to be running power
Old 08-31-14, 11:37 AM
  #37
kevno6
kevno6's Avatar
I tapped into lighter fuse. Never thought about that. What should I tap in to
Old 08-31-14, 03:44 PM
  #38
kevno6
kevno6's Avatar
I noticed other guys used lighter fuse also. But my fog light switch off when headlights come on. I really want them on with headlights.
Old 08-31-14, 05:01 PM
  #39
lostape45
lostape45's Avatar
Not sure if it will help at all but I'm just throwing out suggestions. Mine is hooked up to the gauge cluster fuse
Old 09-12-14, 11:21 AM
  #40
SharpGent
SharpGent's Avatar
I would love to do this on my 04 330. I want to be able to choose the DASH between Auto and ON on my switch so it turns on the fogs only.
I'm comfortable opening things up, I just don't know whether someone has already done the mod on my model.
Old 10-16-15, 03:52 PM
  #41
Vinnnocc
Vinnnocc's Avatar
I just did this mod but I removed just as fast as I did it.
I don't see the point to have fogs on all the time. I'd like to turn them off. With my switch
Also they go off once you turn your headlights on. High or low
Maybe I did it wrong but I'd like to have control of them and have them on with low beams and day time running lights
Old 11-30-15, 03:11 PM
  #42
jdmvip
10th Gear
jdmvip's Avatar
Is it possible to just keep the relay off and jump 2 pins on the harness side and make the fog lights stay on with the car and turn off with the car ?
Old 04-21-17, 05:05 PM
  #43
DKinATL
DKinATL's Avatar
Bump for a question. The above question has me worried about doing this mod. Is there a way to mod the car to be able to utilize the "Fog on / off" switch to control the fogs and fogs only at will? Thanks
Old 04-26-17, 07:44 AM
  #44
01LEXPL
01LEXPL's Avatar
I never ended up doing this on mine, but that was my hesitation... It's cool to be able to use the stalk, but then if its on, when I don't want them to be .... well...
My thoughts were to simply do a re-wire entirely...bypassing the OE relay entirely. Coupled to a "generic" wiring kit, like they use for light bars, and these vendors can easily match up the OE switches from other toyota's.
Sort of reinventing the wheel, but it's not a huge amount of work, the harness is dummy proofed, and you can choose wherever/whatever switch to use. The toyota-swtiched ones are few bucks more, but if you're happy with a generic, they're under 10$
Attached Thumbnails Fog lights switch Mod-c6822698929047f68d9523cfce03d6739a2613cf9ac853cfd2333310cdccd273c7cd9bd2bf269b3626d2568356e03346.jpg
Old 10-14-21, 04:37 PM
  #45
BillDwall
BillDwall's Avatar
Originally Posted by MASH835
Fog Lights Switch Mod (so you can switch on the fog lights anytime)
This mod is for ES300 models '97 to '01.
DISCLAIMER:
Try this modification at your own risk. I'm not responsible for any personal injury/death, mistakes/long term effects and/or damage to property.
The procedure posted here is based solely on my experience with my 2001 ES300. Wiring and connectors can vary widely between models and years so always verify your car before making any connections.
I used BananaGS mod as starting point it is very helpful. However, you will not need to disassemble anything except may be the coin box to reach to the fuse block and connect the wire (see below).
It is also very important that you check if it works for you (in step #3).
Step 1:
Locate the fog light relay. You can put your finger on it and feel clicking sound when you switch on the fog light while the headlights are also on.
I didn't read all of this I just want to ask does it cut out the DRL cuz I need this in my life
Luxlex5
09-01-18 05:54 PM
doodlebug
03-16-17 04:46 PM
asian43200
02-01-09 10:26 AM
avalon42
01-21-09 08:41 PM
Quick Reply: Fog lights switch Mod
