Power St leak? what can I do?
Old 09-09-17, 01:03 PM
mikek753
mikek753's Avatar
Question Power St leak? what can I do?
Hello all,
I got fluid leak, like 5-10 drops overnight - passenger side
color wise it's close to power steering fluid
this is what I see from under car
Power St leak? what can I do?-dsc06152sm.jpgPower St leak? what can I do?-dsc06156sm.jpg
Is it really Power Steering fluid?
How I can repair this?
Should I look for any quick fix like Auto-RX or etc? Or replace the hose?
Thanks
Old 09-09-17, 01:20 PM
mikek753
mikek753's Avatar
Exclamation another pic
how do you manage to clean in that tight space?
What to use to clean? What kind of degreaser to use?
Hot to make sure it's the hose and isn't pump or etc?
thanks
Old 09-09-17, 01:45 PM
Received 3,036 Likes on 2,550 Posts
Could be engine oil or transmission oil or a mix. Most any degreaser in the cleaning section of your favourite store will work, spray it down wait a bit then hit it with the pressure washer (don't get too close to the various components). As for access that looks a lot better than some cars I've worked on, BTW the most common PS hose failure is the "high pressure hose" take a look on Rockauto to see what it looks like.
To diagnose first do your cleaning, let dry for a bit then start the engine and watch.
Old 09-09-17, 01:57 PM
mikek753
mikek753's Avatar
thanks for prompt reply.
I checked oil and PS fluid levels - oil is stable at top dot, but PS is at MIN level, so I thought that one for PS leak instead of Engine oil
I'll check for AT fluid, but it's red color, so I didn't check at all.
Old 09-09-17, 03:19 PM
When I said transmission fluid I'm talking about the ATF in the power steering system, which uses transmission fluid.
mikek753 (09-09-17)
Old 09-09-17, 04:51 PM
mikek753
mikek753's Avatar
Exclamation where I saw PS leaks
in blue that I see it collects
in red that I saw PS leaks when wheels were in complete left or right position, while engine was running
looks like seal doesn't hold the fluid under pressure
what are my options?
1. replace with like Prestone Power Steering Fluid Plus Stop Leak https://www.walmart.com/ip/Prestone-...32-oz/20746454
2. get pump seal kit and replace seals
3. just add "stop leak"
4. etc
thanks
Old 09-12-17, 12:22 PM
mikek753
mikek753's Avatar
I plan to add dye to PS tank and use UV light to search for where it's leaking
all are so tight that isn't easy to see
from hood I didn't see anything
under engine I can't go up much to clean hoses
how did you detect leak position?
Old 09-12-17, 01:39 PM
crwys
crwys's Avatar
Originally Posted by mikek753
Attachment 466225
4. etc
thanks
I used this for my power steering leak. Not a permanent fix but should get you by for a few months.
https://www.amazon.com/gp/aw/d/B000NVW1LM/ref=ya_st_dp_summary?ie=UTF8&psc=1
Old 08-18-20, 08:07 PM
SolidJ
SolidJ's Avatar
Did this work? I plan to use just to get by for 2-3 months. Mine is leaking behind the pulley.
lo_dit
02-18-19 05:24 PM
Luxor
Performance & Maintenance
66
02-28-18 01:38 PM
91LS400LEX
42
03-14-15 01:47 PM
jshooter55
GS - 1st Gen (1993-1997)
10-08-13 08:01 PM
hdwizard
04-27-10 10:42 AM
Quick Reply: Power St leak? what can I do?
