ES330/300 DIY (do-it-yourself) & technical tips
Old 07-19-13, 06:35 PM
  #121
imherenow
imherenow's Avatar
i think this should go here:
https://www.clublexus.com/forums/es3...squeaking.html
Old 07-20-13, 08:44 PM
  #122
Mythotical
Mythotical's Avatar
Default wrong power steering fluid
Just something that has haunted me all my life as a Mechanic. It seems that almost every Lexus or Toyota that I have ever test drove, bought for myself or worked on for a friend has had plain off the shelf power steering fluid in the power steering reservoir when on the cap and in the manual it clearly said use Dextron II or III. And let me tell you I have had to replace so many rack and pinion assembly's because of that simple fact. So please use the correct fluid in the system.
Old 08-12-13, 06:39 PM
  #123
Young50
Young50's Avatar
Wink Car surging problem
I have a used es 2004 and it just started surging in 1 & 2 shift. Do you know what cause it and how can it be fix
without going to the dealer?
Old 08-13-13, 06:15 PM
  #124
speedkar9
speedkar9's Avatar
Alternator / AC belt and power steering belt DIY:
greens6 (01-04-17)
Old 09-16-13, 03:36 PM
  #125
speedkar9
speedkar9's Avatar
DIY: V6 Valve Cover Gasket Replacement
https://www.clublexus.com/forums/es3...placement.html
Old 09-16-13, 10:00 PM
  #126
aikibro
aikibro's Avatar
Great job Speedkar9...
Old 11-24-13, 02:19 PM
  #127
gt99hp644
gt99hp644's Avatar
Default Trans wont move in drive, speed sensor dtc also?
Have a 96 ES300. Trans works fine in reverse but will not move in D or L unless you redline the car. The car also spit out P0500 for vehicle speed sensor. I added a little fluid and left dipstick out and tried moving the car and it started smoking out of the filler tube. Car has 160k. Not sure if I can replace the sensor? Maybe rebuild if clutches are gone? Greatly appreciate any input.
Old 12-24-13, 10:56 PM
  #128
mrLexLuter
mrLexLuter's Avatar
i know mine the lens inside had film on it so cleaning the outside lens was pointless... you can ebay it or go to salvage yard....like 50-75$ not hard to take out think 2 bolts at the top?
Old 12-24-13, 11:14 PM
  #129
mrLexLuter
mrLexLuter's Avatar
Originally Posted by DanStout
Yesterday the AC quit and all items on the bottom of the center console controls (fan controls, front and rear defroster, heat, outside temperature indication, etc.) are dead. Have looked at fuses but don't see any blown. Any suggestions?
sounds like a relay in your engine compartment.... did you check the fuse by the engine bay...also under the battery there is a eletric plug that tends to come lose check that
Old 01-16-14, 01:35 AM
  #130
babycoco92
babycoco92's Avatar
Hi im new to this, I have a 1992 lexus es300. Wanted to know if 18" rims would fit on my car, tires are 225/40ZR18 Venezia Crusade HP 92W
Fdavis13 (09-01-22)
Old 01-23-14, 05:58 PM
  #131
kody
kody's Avatar
How about the ofset ? I use +38. 18x8. Tire 225/45 r18
Fit but rub when bumping.
Old 02-01-14, 10:59 PM
  #132
dysopheak
dysopheak's Avatar
Hi ! I have a Lexus ES 330 2005. I lost a steering wheel screw cap and did not know where to find those. Please help me. Thank !
Attached Thumbnails ES330/300 DIY (do-it-yourself) & technical tips-img_1070.jpg
Old 02-05-14, 12:40 PM
  #133
gtstcactus
gtstcactus's Avatar
You could try a wreckers or pick a part style wreckers....
I quite often see on ebay various kinds of Toyota / Lexus (and other makers) clips, special screws, caps etc - all the various bits of trim & trim finishing etc,,,,
You could possibly try your local Lexus / Toyota dealer they might be able to supply them, likely at some cost!!
Old 02-26-14, 10:05 AM
  #134
jonny01
jonny01's Avatar
I have a 1999 lexus es300 and i am throwing a few codes out can anyone help p1135 p1155 p1351 a random misfire code and a 2 4 6 misfire codes any help would be great
Old 03-31-14, 07:23 PM
  #135
Bumbobee
Bumbobee's Avatar
Anyone have a timing belt DIY guide for a 2001 ES 300?
Quick Reply: ES330/300 DIY (do-it-yourself) & technical tips
