Go Back   Club Lexus Forums > Lexus Model Forums > ES Models > ES300 and ES330
Sign in using an external account
Register Forgot Password?
ES330/300 DIY (do-it-yourself) & technical tips
Thread Tools Search this Thread Display Modes
Old 03-21-09, 12:34 PM   #76
70GS455
Trader Score: (0)
Just got done with removing the rear portion of the center console on my 03 ES300 so I could fix the front cupholder.
1. Remove the trim from around the gear shift ****. I used my fingers to pry up the rear section first, then pull up and to the rear of the car. Helps to have the trans in neutral. It has wires so don't drag it too far away.
2. You will see 2 phillips screws that join the front and rear sections of console. Remove those 2.
3. At the rear, remove the upper plastic piece with the air vents. With your fingers, pull straight back.
4. At the rear, remove the lower trim piece, pull straight back.
5. With the lower trim piece off, you will see 2 bolts attached to the floor, a few inches in (under the storage box). I used a swivel, socket, and extension. They are kinda hard to get to when putting back in.
6. The whole console assembly should lift straight up. But first, there are 2 places on the sides where the carpet hooks over 2 plastic tabs on the air ducts. They are about mid-way betwen front and back of the console. Find them with your finger tips and just slip them off. There is wiring attached so take care.
7. I had to replace the cupholder which was pretty easy, it's just 4 screws.
8. Installation is just the reverse.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
70GS455 is offline   Reply With Quote
Old 06-20-09, 08:23 PM   #77
Patrick Th
Trader Score: (0)
This is an awesome post. I have a noise comming from my right rear over bumps and I was going to purchase a complete srut/spring assembly. Now I know how to access it.
Thanks. If anybody has any more advice on my clunk over bumps. Plz contact me newsk@attg.net
Patrick Th is offline   Reply With Quote
Old 06-24-09, 01:46 PM   #78
209
Trader Score: (0)
hey your thread was very helpful but I was trying to get into the one were you remove
the stock sterio off an 97 es300, but some advertisement or something like pops up?
was wondering if you could help me or any one els with info.oh and does the car have an
factory amp that I have to disconect?
209 is offline   Reply With Quote
Old 07-10-09, 08:49 AM   #79
tmf2004
5% Club. Killing it!!!
Trader Score: (14)
tmf2004's Avatar
anthonymichael34 tonylexus99
The link for stereo removal for 97 ES is not working.. I may need to do this.. Thanks
__________________
2GS FAQ and DIY
99 GS400
2012 Kia Optima SWP TURBO
Quote:
Originally Posted by VtotheJ View Post
Drone is overrated......let the V8 breathe!
tmf2004 is online now   Reply With Quote
Old 07-10-09, 06:31 PM   #80
ES 300
Trader Score: (0)
Default Replacing Air Intake Hose
I'm going to be replacing my air intake hose on my 92 ES300. Has anyone done this before and have any tips? It looks straight-forward but just thought I'd ask just in case.
Any advice is appreciated. Thanks very much
ES 300 is offline   Reply With Quote
Old 07-13-09, 05:57 PM   #81
peter12345
Trader Score: (0)
Smile
hi. i need DIY for my 92 es 300 rear vale cover gasket change. any body know or did it before. thank
peter12345 is offline   Reply With Quote
Old 08-19-09, 04:39 PM   #82
lexus905
Trader Score: (0)
any one know where to get a wood trim kit for a 1994 lexus es300? and a woodtrim double din faceplate
lexus905 is offline   Reply With Quote
Old 11-21-09, 03:41 PM   #83
markarko
Trader Score: (0)
Hi all,
Just to save someone the hassle that I just went through. I've got a 2004 ES330 and had to replace the cupholder. The above instructions did *NOT* work for me. Instead skip #5 and #6 above...you do not need to remove the two bolts at the bottom to get the center console up. Do this instead:
1. Inside the bottom large area in the center console is carpet. Pry up the carpet and you'll see two bolts. Remove these two bolts.
2. Remove the 4 screws on the outside of the center console.
3. Lift up the unit and proceed with #7 from the previous post.
Hopefully that helps someone out there!
-Mark
markarko is offline   Reply With Quote
Old 12-01-09, 03:19 PM   #84
ClubES300
Trader Score: (0)
Hey can someone PM me on how to remove the rear bumper cover off a 94 es300? Thanks!
ClubES300 is offline   Reply With Quote
Old 12-01-09, 08:14 PM   #85
hksnlper
Trader Score: (0)
hksnlper's Avatar
Hey Guys I am trying to replace the Valve Cover Gasket on my wife's 97 ES300 both front and back. Any guide on that. Any help will be appreciated.
hksnlper is offline   Reply With Quote
Old 12-01-09, 09:36 PM   #86
llcoolpass
Trader Score: (0)
llcoolpass's Avatar
Send a message via AIM to llcoolpass
you remove [upper] intake manifold, remove valve cover
[use autozone for guide, or one you find on here, or one you find on toyota forum or the FREE DOWNLOADABLE FSM [factory service manual] that is all over, you can't miss it if you SEARCH for it]
clean everything that will come into contact with seal and rtv with acetone [nail polish remover].
clamp it down with washers and to a higher torque spec [14 ftlb] or using a ton of rtv in the groove and blabla bla like they say here:
http://www.toyotanation.com/forum/sh...64#post2994764
and my thread:
http://www.clublexus.com/forums/es300-and-es330/421061-gotta-leaky-valve-cover-gasket-solution-new.html
__________________
1993 5-speed Lexus ES300.
2.5% were made this way. 153,000mi
Me Racing
http://www.youtube.com/watch?v=ppKDVUgNf48
Lexus ES 300 commercials:
http://www.clublexus.com/forums/es30...-es-300-a.html
llcoolpass is offline   Reply With Quote
Old 12-02-09, 02:02 PM   #87
ClubES300
Trader Score: (0)
So i found all the clips and removed everything i could find for the bumper. But its stuck! Right under the license plate it WONT BUDGE
Old 01-15-10, 02:33 PM   #88
rmahbub
Trader Score: (0)
Default How to Access and Replace 98 ES300 Front Turn Signal Indicator Cover
Can you guys help?
__________________
LX470 --- his
ES300 --- her
rmahbub is offline   Reply With Quote
Old 01-15-10, 03:46 PM   #89
DRACO A5OG
Trader Score: (0)
DRACO A5OG's Avatar
You will need to remove the front head light assembly to gain access to that side marker/flasher. No worries it will not put it out of alignment, just a hassle because you have to remove the bonnet and those plasitic push clips tend to break due to age. Go to auto zone and pick some up, you will need them
__________________
Jim
96 ES300 Gen 2, Black/Dark Grey, Palomino Interior Leather. 304K on the Clock 07/2013
85 Carrera Targa
DRACO A5OG is offline   Reply With Quote
Old 01-15-10, 03:58 PM   #90
angmedic91
Trader Score: (5)
angmedic91's Avatar
Angmedic911 angmedic
Quote:
Originally Posted by rmahbub View Post
Can you guys help?
On the 98, no need to remove the headlight, the 3rd gen lights are different from the 2nd gen. 97-2001 is considered 3rd gen. To remove the front turn signal lamp, open up the hood and and on top of the headlight near the corner lamp you want to remove is a phillips screw, underneath that youll notice a plastic tab that connects to the corner light. Remove the screw and then with fingers, grab the tab and with your other fingers grab the corner light at the farthest edge from you and wiggle and pull the light towards you, you should be facing the the headlight/corner light. It might be hard at first if it has never been removed before, it should pop straight forward, then you'll have access to the bulb and wiring. To replace is just opposite, but make sure the side tab on the corner light slides into the side recieving end on the headlight. Once properly in, replace screw on top and your done.
__________________
Robert
HID 8K LB & 6K DL/TSW Snetterton/K-Sport Coilovers/Drilled & Slotted Rotors/VIS Front Lip/Eyebrows/Clear Corners/NST Underpulley/Rebored TB/01 Front Grill/Optima Battery/Solara SB/Window Tint/01 Wood Grain Steering Wheel/Wood Dash Kit/RX300 Wood/Leather Shift ****/LED Int. & License Plate Lights/ED Side Skirts/Chrome Pillar Posts/Chrome Magna Flow Exhaust/LED Rear Spoiler/TRD RSB/01 Taillights
angmedic91 is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
LS460 Wind Noise Fix (continued discussion) encore888 LS460, LS460L and LS600h 827 09-30-14 05:42 PM
Can someone help me find a research topic for my paper? chi123 The Clubhouse 9 12-06-12 01:32 AM
Tags
05, 2002, 330, change, chip, diy, es, es300, es330, key, open, performance, plug, spark, strut, trunk
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
