Go Back   Club Lexus Forums > Lexus Model Forums > ES Models > ES300 and ES330
Sign in using an external account
Register Forgot Password?
ES330/300 DIY (do-it-yourself) & technical tips
Thread Tools Search this Thread Display Modes
Old 09-25-07, 12:13 AM   #46
Myounger
Trader Score: (0)
Thank You.
lexus wanted a $1000 to reprogram my remote after car battery replacement.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
Myounger is offline   Reply With Quote
Old 10-11-07, 08:53 AM   #47
zzzzkev
Trader Score: (0)
Default ES300 Seat Belt
Quote:
Originally Posted by zzzzkev View Post
Oh well, I started to replace the seat belt and there's a tiny snag...you need a special T-40 torx socket with a female center. Can't say that I've ever seen one. Went to Sears, Advance Auto Parts, and Lowe's. Must be a Snap-On or something. Any ideas where I could find one of these whizbang gadgets??
Replaced the seat belt for my daughter's "new" car ('97 with 169K mis.). It was actually quite simple after all. Need a 10mm socket and 14mm. forget the special torx issue.
Carefully remove the interior trim pieces and the mechanism has three bolts holding it in place. The over the shoulder connection is also easy to remove. Do NOT over torque the 10mm bolts (like I did). I had to fix my mistake by purchasing a new one at the dealer (~$2). Backed out the broken piece and replaced it. Works like new again!
__________________
zzzzkev is offline   Reply With Quote
Old 10-27-07, 06:41 PM   #48
GrahamHill
Trader Score: (0)
GrahamHill's Avatar
What about that distributor change (timing change) to get that extra couple HP?
__________________
'95 Lexus ES300, '97 Camaro Z28, '99 Camaro Z28
GrahamHill is offline   Reply With Quote
Old 10-31-07, 11:56 AM   #49
BadViper22
Trader Score: (0)
BadViper22's Avatar
How to Clear a Second Gen Tail Light with a Hair Dryer.
http://www.clublexus.com/forums/es300-and-es330/315603-how-to-clear-a-2nd-gen-tail-light-w-a-hairdryer.html
__________________
Current Ride: 06 Corolla S
Sig by Seize
BadViper22 is offline   Reply With Quote
Old 11-15-07, 07:21 PM   #50
96Lexboy
Trader Score: (0)
96Lexboy's Avatar
Quote:
Originally Posted by EerFoolWVU View Post
I spent somethin like 5 bucks on this via eBay but i figured I'd post it on here for free in hopes you guys might be able to return the favor with my GPS installation!
Remote Keyless Entry Programming Procedure
(Customer Program Method)
1. Sit in the driver's seat and lock all the doors.
2. Unlock and open the driver's door.
3. Insert the key into the ignition and remove it (don't turn it...just remove it).
4. Using the MANUAL lock switch on the driver's door, lock and unlock the door 5 times.
5. Close the door.
6. Open the door.
7. Lock and unlock the driver's door 5 times (with the power switch).
8. Insert the key into the ignition and turn it to the "ON" position.
9. Remove the key.
10.The driver's door will now lock and unlock itself one time.
11.Press and hold the "LOCK" button on the key fob for at least 1 second.
12.Close the driver's door.
13.Open the driver's door.
14.Press and hold the "LOCK" button on the key fob for at least one second.
15.Close the driver's door.
16.Press and hold the "LOCK" button on the key fob. The door will lock.
17.Press and hold the "LOCK" button on the key fob again. The door will unlock.
ok so i was trying to program my remote, and i sat in the car and locked the doors, and i manually unlocked the driver door and opened it... so what happens? the friggin alarm goes off! i couldnt turn it off because the remote wasnt programed... so i stuck my key in the ignition the alarm stopped... but now i cant turn on my car!!!!
can someone help me ASAP!!!!
96Lexboy is offline   Reply With Quote
Old 11-15-07, 09:08 PM   #51
96Lexboy
Trader Score: (0)
96Lexboy's Avatar
never mind that... i got it
Old 02-24-08, 08:57 PM   #52
lexusk8
Trader Score: (0)
lexusk8's Avatar
Send a message via AIM to lexusk8 Send a message via Yahoo to lexusk8
MASH835 recently did an install for a tire pressure monitor system in a 2001 ES300. This will most likely apply to all 3-gen ES (1997-2001).
http://www.clublexus.com/forums/es300-and-es330/338027-tpms-installed-on-01-es300.html
__________________
2011 CT200h Premium (Obsidian on Black Nuluxe) - Nitto Motivo 225/45/17, DDM 35W/5000K HID Slim kit, Road Magnet springs, Beat-Sonic FDA3 antenna, super white LED reverse lights
2013 GS350 F-Sport (Starfire Pearl on Black)
lexusk8 is offline   Reply With Quote
Old 03-25-08, 10:32 PM   #53
lexyES300
Trader Score: (1)
Lightbulb 2nd gen es300 door lights
Does anyone know how to change the front door side lights on a 2nd generation ES300??? i got the the cover off but cant seem to take out the bulb. Thanks in advance!
lexyES300 is offline   Reply With Quote
Old 03-30-08, 12:28 PM   #54
Gedgardo
Trader Score: (0)
I just want want to know how easy is to replace the front wheel bearing. The driver side started to make some noise. I'm already bought it. Thanks.
Gedgardo is offline   Reply With Quote
Old 03-30-08, 08:07 PM   #55
dicespice
Trader Score: (0)
Actually, I replaced mine today with some LED replacement bulbs. It was a little bit hard but if you are careful you can pull them out with a pair of pliers.
I used a pair of needle nose channel locks but I think I could have done it with pliers. They pull right out. Needle nose with some surgical tubing would be a good idea. BUt I just closed my eyes, and pulled. Didn't want to get any glass in there in case they broke.
I would be easier if you can take the gray light holder out. The is one clip that holds it in to the door panel and it pops right out and back in without having to pull the door panel off.
Good luck. remember close eyes and pull.
dicespice is offline   Reply With Quote
Old 04-22-08, 03:15 PM   #56
ajbboi
Trader Score: (0)
ajbboi's Avatar
Andrewjbianchi
where can i learn how to clear the tail lights on a 97-99 es300?
ajbboi is offline   Reply With Quote
Old 04-24-08, 01:57 PM   #57
lexusk8
Trader Score: (0)
lexusk8's Avatar
^ So far no one has successfully cleared those tailights but you could be the first and follow the same baking method as for the headlights. I recommend having a spare set of tailights in case you mess up.
__________________
Old 04-30-08, 06:08 AM   #58
lexuslhs
Trader Score: (0)
Default 2005 es330 trans and paint issues
just purchased a 2005 es330 blue shale mica...love the car except for two things..the trans shift points are not the same all the time..rpms "raise"excessively between shifts..i read the post regarding the tsb#tc004-03..will this fix my problem?..now the paint, the bumpers look a different shade..is this common with the blue shale mica..the difference is quite obvious at certain angles... i didnt see it when i purchased the car...the bumpers were sprayed as part of the "certified" appearance maintenance..does anyone out there have the same problem,if so, is this normal?
lexuslhs is offline   Reply With Quote
Old 05-05-08, 01:30 PM   #59
lexusk8
Trader Score: (0)
lexusk8's Avatar
^ Regarding the transmission, inform yourself in this specific tranny thread (http://www.clublexus.com/forums/es300-and-es330/87068-02-05-es-transmission-fix.html) for the '02-'05 ES. That's a whole another topic to be discussed. Regarding the paint mismatch on the bumpers, it sounds to me that your car was involved in a previous accident and that the body shop did not employ a correct match of the body paint on the bumper. This happens all too often when buying used cars from dealers or private owners since the Carfax report does not always show signs of accident history.
Remember guys/gals, please keep this thread on topic (i.e. post up DIY-related threads or posts for the ES300/330).
__________________
Old 05-29-08, 02:29 PM   #60
kphu
Trader Score: (7)
http://www.linkedin.com/pub/ken-phu/5/556/326/
Default How to by pass 97-01 ES300 stock amplifier
ok so according to the wiring diagram for the 3rd gen ES300. Here's the speaker wires.
Cut just the wires in the diagram (i.e. don't cut the non-speaker wires as some of them are ground and power cables that connects to relays, etc) and plug the harness back into the amp (very important that you plug the harness back into the amp). If you accidentally cut the wrong wire reconnect them either with a soldering gun or butt connector. If you use a soldering gun I'm sure you know to tape them up with electrical tape or use plastic shrink tubes.
Connect the wires that are detached from the harness accordingly to your speaker wires from your head unit i.e. Right rear cables to right rear speaker cables from head unit, etc.
ES330/300 DIY (do-it-yourself) & technical tips-97esampbypass.jpg
__________________
1994 ES300 Sold
2002 GS430 - NAV, MLS, GR2 w/Tiens spring, TTE 19s.
2003 GX470 - NAV, MLS, T4R 18s.
Sometimes the sun shines on a monkey's azz...I wonder when that azz would be mine.
kphu is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
LS460 Wind Noise Fix (continued discussion) encore888 LS460, LS460L and LS600h 827 09-30-14 05:42 PM
Can someone help me find a research topic for my paper? chi123 The Clubhouse 9 12-06-12 01:32 AM
Tags
05, 2002, 330, change, chip, diy, es, es300, es330, key, open, performance, plug, spark, strut, trunk
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
