92 ES 300 brake bleeding order
I tried a search but came up with different procedures and for other models. Can anyone tell me the order to bleed the brakes on a 92 ES300 or provide a link with the correct procedure? On my other car it uses a X system so you have to start with the right rear, then left front, then left rear, then right front. Is it the same for the 92 ES or do you just start with the furthest right rear, left rear, right front and left front. Thanks.
Start with the one furthest way from the master cylinder. So that means... back right, back left, front right, then front left. You'll want to have 2 people helping you when you bleed the brakes. One person in the drivers seat. another person pouring brake fluid into the brake fluid resovoir and you will be manning the bleeder screw. have the guy pump the pedal a couple times, to build up pressure in the brakes, then you go ahead and untighten the bleeder screw then tighten. next wheel same thing. next wheel same thing. last wheel same thing. Person manning the brake resovoir tho... they gotta constantly be pouring in brake fluid as the resevoir depletes itself. simple as that. One word of caution however... be careful because certain brake fluids are known to take off the paint on your car. Other than that, have fun, good luck .
werewolf
Maintenance
05-12-10 09:51 PM
LexFather
04-16-07 01:35 PM
