Engine Swap compatibility
Does anybody know if engine subframe of 1993 ES300 is compatible with 1999 subframe. I have a wrecked 1999 ES300 that I would like to use as a donor car. I plan to install '99 subframe with drive train on 93 ES300. The wire harness and ECU will also be replaced.
-- Does the 99 and 93 ES300 subframe mounts tin the same place? Even if engine mounts are different, the subframe mounts are probably in the same place?
-- Can anybody check if part # is the same for '93 and '99 subframes?
Lexus Connoisseur
Originally posted by mikhailw
Anybody should know something?
Are you just saying it or you know for sure? I have a guy from TOYOTANATION.COM who claims that engine subframe is identical. In fact, he swaped his engine from '92 to new engine from '98.
He claims that everything fits perfectly.
hsiehd
03-20-10 03:59 PM
