squeaking noise A/C help!!!
Old 03-27-04, 11:46 AM
hoolcat
hoolcat's Avatar
Red face squeaking noise A/C help!!!
When I turn My A/C on I get a squeaking noise inside my car. All sounds good outside my car. It sounds like its coming through the vents. This only happens with the A/C on and it will stop as soon as i shut it off.
Old 03-27-04, 01:47 PM
Lexbox
Lexbox's Avatar
This happens to me too if I put the A/C full blast.
Old 03-28-04, 05:45 AM
lexusk8
lexusk8's Avatar
It sounds to me like this "squeaking noise" is coming from a problem with your A/C compressor. I assume you have no problem getting proper cold or hot air through the vents when the A/C is turned on, correct? The compressor for the A/C would need to be checked out if you have plenty of A/C refrigerant.
Old 03-28-04, 07:57 AM
amf1932
amf1932's Avatar
It could be the fan motor that is causing this squeaking noise. There is a button on your control panel that can manually shut off the air conditioning compressor while letting the rest of the system operate. Try doing this to see if the noise disappears. If it does, then it could be the compressor or belt that is at fault. If it doesn't, then it could be the fan motor.
Clutchless
HS 250h Model (2010-2012)
08-09-15 01:10 PM
acenase
Performance & Maintenance
09-27-07 03:42 PM
DrewGS350
02-12-04 10:26 AM
Quick Reply: squeaking noise A/C help!!!
