Camry V6 = ES300? Tire Rack giving me probs
Old 01-13-04, 08:42 AM
juan01
juan01's Avatar
Default Camry V6 = ES300? Tire Rack giving me probs
Well, I ordered H&R springs for the Camry 92-96 V6 models. This is what I got from one of their sales' reps.
We spoke with H & R and they say the springs for the Camry V-6 are not aggressive enough and most likely you would have trouble getting those installed. If you still want them I can check with our Sales Manager and if he approves the sell there would be no returning the springs, but I am not sure if he will even allow them to be sold.
We show that the ES300 has different mounts in the rear and that may not allow the springs to mount correctly.
What's the deal with this? Anyone know if I will run into any troubles with these springs?
Old 01-13-04, 09:32 AM
juan01
juan01's Avatar
We can sell the springs but they are not returnable and any fitment problems would be your responsibility. Just let me know if you still want and the tires which are wider than we recommend would be the same situation.
Alright, I just need reassurance that I won't have problems? If not, I'll go ahead and go for the Intrax springs from Todd/TM Engineering.
Old 01-13-04, 02:22 PM
binelus
binelus's Avatar
The ES300 is suppose to have the chassis as the Camry !
Old 01-13-04, 02:24 PM
juan01
juan01's Avatar
Yea... I know. I don't know what the deal is. Also, I haven't heard of anyone using H&R for 92-96 models...So I really don't know how well they run or whatever.
I might go ahead and go for the Intrax.
Old 01-14-04, 08:49 AM
d3m0n1c
d3m0n1c's Avatar
its the same car, but ours has a prettier exterior and interior..
i dont fore-see that being a problem, if it is, there are places that sell them "for" the lexus...
if there is a difference i would like to know as well
Old 01-14-04, 06:41 PM
juan01
juan01's Avatar
Well, I went ahead and ordered Intrax 1.6" from Todd and TM Engineering. I don't get why Tire Rack does that, I guess its a policy to ensure there are no returns unless the problem is actually with the product itself. Plus, it drops a little more than the 1.3" H&R.
Old 01-14-04, 08:27 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Nothing is ever the same on anything.
Example:
SC300 And Sc400.... same body right? then why dont the window regulators fit from one to the other?
Answer: regulator was extended 1/2 inch to make sure you couldn't use them on the other model.
Old 01-15-04, 03:26 PM
squarehat
squarehat's Avatar
I went to the Tire Rack Upgrade Garage, and the only springs they're showing for the '96 ES are Eibach Pro-Kits, with a 1" drop. That's perfect for me, as I only want to snug the fender gap a little bit more with my 17s, don't want to worry too much about camber or looking funny when I put the stock wheels back on for the winter.
I'm guessing that you want these H&Rs because of a lower drop or desire for even tighter handling.
Old 01-15-04, 03:48 PM
juan01
juan01's Avatar
Yea, 1" will still leave a funny looking gap at front, so I was looking for lower. H&R goes 1.3" and Intrax goes 1.6". My first choice was H&R because of what people have said about Intrax. But it's all I have so I guess it will do for now.
Old 01-15-04, 03:52 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,127 Likes on 1,297 Posts
I'd suggest you PM our ClubLexus rep from the Tire Rack (Brandon) with a link to this thread and see if he can help investigate the difference.
Old 01-15-04, 04:04 PM
juan01
juan01's Avatar
Hey Dave, thanks for the suggestion...But I have already paid for my Intrax springs.
Square, why don't you go and try for the H&R Camry?
Old 01-15-04, 07:03 PM
lexusk8
lexusk8's Avatar
Default Keep this in mind...
You guys who are thinking of getting a spring kit like Eibach or H&R should heed caution when installing them into the ES. The factory struts are not going to last long with the upgraded springs, so you mind as well need to purchase a new set of struts like KYB, Tokico and similar. Other things to worry about your ride down the line include wheel balancing and alignment, speedometer accuracy, any rubbing on the suspension components, etc.
An interesting story here... I went to a local auto parts shop months ago and inquired about the Eibach Pro-Kit for my '01 ES. The guy behind the counter looked at me funny, saying and wondering why install such a spring kit on a luxury sedan (duh, for handling and looks). Then he turned to the inventory from the computer and said there's none available to fit in my ES. It was alright though, I just wanted to see the guy's reaction from the inquiry...
Old 01-15-04, 10:55 PM
juan01
juan01's Avatar
As a matter of fact, I ordered Tokico from "jdmwerks" on Ebay and received them today!!
Balancing and alignment I can get done.. How do you get your speedometer "fixed" when there is an upgrade to the suspension/wheels... and how will I know if there is rubbing on the suspension?
Old 01-16-04, 09:35 PM
lexusk8
lexusk8's Avatar
I found the following link from an old post. This is good reference to determine the accuracy of your speedometer with the tire sizing changes. You could get your speedometer recalibrated at a qualified tire shop, but I hear it's very expensive
Speedometer changes
Not sure how wide your new tires are going to be, but be careful of getting wider tires as they could cause rubbing along the suspension components or the fender, especially when taking tight turns or going over bumps. If you do a search for "suspension rubbing" in the forums, you should yield some useful info. Hope this helps Juan.
Old 01-16-04, 11:08 PM
juan01
juan01's Avatar
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
205/65-15 5.2in 12.7in 25.5in 80.1in 791 0.0%
225/40-18 3.5in 12.5in 25.1in 78.8in 804 -1.6%
Doesn't look like much difference I guess? I'm not sure.. lol
Thanks for the warning on the tires and stuff, I kept on eye out on making sure I bought the right size rim and tire to minimize (if any) rubbing. I have 18x7.5, 42mm offset rims and 225/40/18 tires.
Quick Reply: Camry V6 = ES300? Tire Rack giving me probs
