ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Tips for removing bolts trunk lip spoiler
Old 12-29-16, 01:07 PM
LVFlier
LVFlier's Avatar
Default Tips for removing bolts trunk lip spoiler
Hey CL,
Does anyone have any tips on removing the 4 bolts from the back of the trunk lip spoiler, I do not want to drill holes. I was not sure at the time when i ordered it if I wanted to have it permanently installed no seeing it and reading I would rather tape it. Plus I did not buy the template.
Any tips or suggestions?
Thanks
Old 12-29-16, 01:13 PM
Ratchey
Ratchey's Avatar
Originally Posted by LVFlier
Hey CL,
Thanks
It must be after market as the OEMs only have 2 bolts. Without seeing the back it is hard to say, but you might be able to use vice grips to twist them out if they are threaded, and if not, a dremel with a cutoff wheel will make quick work of them.
Old 12-29-16, 01:46 PM
LVFlier
LVFlier's Avatar
It is the OEM part they were nice enough to put 4 on the 15s (16 too i think). I tried to give them a spin but no luck. I might try the dremel if i can find another set of hands I can be a bit shaky.
Old 12-29-16, 05:03 PM
imrankh24
imrankh24's Avatar
Hey CL,
Thanks
I recently installed my spoiler on my 16 with the adhesive only and it had been holding ul great and it has rained a lot to and no movement or leaks or gaps. So you just go with the adhesive
Old 12-30-16, 01:21 PM
Brent1944
Brent1944's Avatar
The ones Ive seen are screwed from inside the trunk into the spoiler.
carid
Club Lexus Vendor Marketplace
02-14-17 04:58 AM
stanweil
12-05-16 06:37 PM
soloist3
11-16-15 06:15 AM
vapid2323
04-29-13 03:38 PM
Quick Reply: Tips for removing bolts trunk lip spoiler
