help with front led turn signals install
Originally Posted by trama09
It's in the manual. And like Brent said - hyperflashing. I just received LEDs today and forget it might need resistors. Nearly got a seize from the hyperflashing
You don't need resistors. I have LED taillights w/o resistors. I never changed the front but have had the rears for 4 years...
Check out this thread from several years ago...
https://www.clublexus.com/forums/es-...-or-not-2.html
Which one did you get/ use?
Did you screw them down to the body? I was thinking about just taping the resistor with foil tape (that can withstand 250 degrees f).
The LED's I bought and installed are listed in a link above from a previous post. I took photos and indicated the type of LED installed. Took me about one hour to install with NO modifications to the car and NO resistors necessary. I left the amber lens in place. the sockets were $29.99 a pair and the decoders were $12.99 a pair from JDMTOY.com. Work perfectly for the last 4 years...
