ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
How Much Should An Oil Change Cost
Old 10-20-16, 08:29 AM
djdrew44
djdrew44's Avatar
Default How Much Should An Oil Change Cost
I usually get my oil changed at the dealer for about $40, but didn't want to make the trip and went over to my local wash & lube. They quoted me $106. Does that sound right?
Old 10-20-16, 09:08 AM
gmanusmc
gmanusmc's Avatar
You did not mention your specific vehicle but if it's a late model Lexus, it most likely requires 0w20 synthetic. $40 is a very good deal but I would confirm they are using the correct oil - sounds like they could possibly be using bulk oil of some type. Is this a Lexus or Toyota dealer? I'm not familiar with "wash & lube" so unable to comment on that.
Old 10-20-16, 10:20 AM
bc6152
bc6152's Avatar
Received 1,234 Likes on 866 Posts
If you're paying $40.00 for a quality synthetic oil change please send me the address. I'd make sure as BG stated, that they're using name brand quality 0w20 synthetic for your car.
Otherwise, an oil change for a newer Lexus can range from about $50.00 on a special offer to about $100.00 at the Lexus dealer. My dealer charges $75.00 for a 2013 Lexus using 0w20 synthetic and a Lexus filter cartridge. Your wash and lube doesn't sound like such a good deal to me. my local AAA garage gets $70.00.
Old 10-20-16, 11:11 AM
djdrew44
djdrew44's Avatar
This is the 6th Gen ES Forum, didn't think I'd need to specify, but I probably should put it in my signature.
As mentioned below, it was at Ray Catena Lexus in NJ.
Wash & Lube was just my reference to a generic local quick lube shop.
$40 was at Ray Catena Lexus in NJ, where I got the car. But it costs me time, tolls and gas to get there.
$70-80 sounds fair, $106 sounds out of line. They tried to tell me it has a special oil filter. I just left.
Thanks to both of you for the responses.
Old 10-20-16, 11:28 AM
Mike728
Mike728's Avatar
$40 would be a steal for synthetic with a filter. Almost what a DIY would run you.
Old 10-20-16, 01:43 PM
gmanusmc
gmanusmc's Avatar
Sorry - sometimes folks with other model and year vehicles mistakenly post in the wrong forum - was just trying to confirm. As others have said, 40 bucks is indeed a great price if they are using a quality 0w20 synthetic oil. Most Lexus dealers charge $100 or more. Something to consider, if you can locate a dependable independent auto service shop near you, they could do the work for a reasonable amount if you provide the oil and filter. Walmart has Mobil 1 Extended Performace in 5 quart containers for around $30 incl tax, and you could hopefully source the filter locally or online. The ES350 requires 6.6 quarts so you could just buy a couple extra quarts or two 5 quart jugs and save the left over toward the next change. The shop we have been using for years does great work and charges 10 bucks if we provide the oil and filter.
Old 10-20-16, 05:51 PM
Received 2,519 Likes on 1,817 Posts
$40 isn't a synthetic oil change. Dealers all the time will use low quality oil, non synthetic oil, etc. If the dealer is using good quality oil, they loose money on a $40 oil change.
Old 10-20-16, 08:57 PM
16silverES
16silverES's Avatar
$40 is a steal if they are using a quality synthetic oil. I get my oil changed for no labor at a friends shop where I worked before. However, if I remember correctly, the 0W20 synth oil costs over $40 per gallon at shop prices... The Lexus OEM filter was about $5 (cheap) from a dealer. For the RX 350 you need a special tool to remove the filter. I'd guess $65 or so would not be out of line including labor. I would be leery of any of those quick oil change places, including Walmart. I've had bad experiences with those types of business before. They are not all bad or crooked, but enough of them are that or incompetent. They can screw up your car.
Old 10-21-16, 03:28 AM
Freds430
Freds430's Avatar
Received 1,056 Likes on 692 Posts
I take my oil filter bought at Lexus Parts World for $5 and 5 quart jug of Mobil 1 purchased at Walmart for $24 to my local Toyota dealer and they charge me $15 labor for the oil change labor. Total cost $44.
Old 10-21-16, 04:50 AM
bc6152
bc6152's Avatar
But your engine takes 6.5 quarts of oil...??
Old 10-21-16, 05:12 AM
Mike728
Mike728's Avatar
I think the hybrid takes just under 5 qts.
Oil capacity (Drain and refill  reference*)
With filter
 Gasoline vehicles 6.4 qt. (6.1 L, 5.4 Imp.qt.)
 Hybrid vehicles 4.6 qt. (4.4 L, 3.9 Imp.qt.)
Without filter
 Gasoline vehicles 6.0 qt. (5.7 L, 5.0 Imp.qt.)
 Hybrid vehicles 4.2 qt. (4.0 L, 3.5 Imp.qt.)
Old 10-21-16, 05:54 AM
bc6152
bc6152's Avatar
Hmmm. I didn't think of that. Thanks Mike.
Old 10-21-16, 06:00 AM
lesz
lesz's Avatar
Received 1,010 Likes on 691 Posts
I've been getting the oil changes for my ES 350 at the local Toyota dealer. Their "regular" price, using the same Toyota full synthetic oil and filter that the Lexus dealer would use is about $70. But they have "loyal customer" pricing for regular customers, and the "loyal customer" price for the full synthetic oil change is $51. When I had my last oil change several weeks ago, I also had a $10 coupon. So, my net cost was $41. I figure that, at that price, it would cost me more to do it myself.
Old 10-21-16, 07:27 AM
I'd be dubious as to whether they actually use the Toyota synthetic oil...
Old 10-21-16, 07:37 AM
lesz
lesz's Avatar
I've checked the labeling on the oil packaging, and it is clearly marked as genuine Toyota full synthetic oil.
I suspect that their marketing strategy is to do oil changes for somewhere around their cost to encourage customers to have other service and repair work done in their shop. And what they charge for other work is also quite reasonable at prices less than half of what the Lexus dealer charges. I've been having all of my work on my Lexus vehicles done there for about a dozen years, and they do now have a loyal customer.
Quick Reply: How Much Should An Oil Change Cost
