Hazard lights not working.. Help
Hi
2013 es350 turn signal lights are working fine but hazard/emergency flushes not working .
Note:
OBD scan not showing anything.
Hazard switch red light working .
15amps turn/hazard fuse fine .
Do you think that the switch it self having a problem??
Note:
Try switching out the fuse with a new one. Sometimes a fuse LOOKS good but isn't. Or, if you have a meter, check for continuity on the fuse. Touch both leads of the meter to both sides of the fuse while meter is set for continuity.
Already did , by meter and test light ...its not fused
i am thinking to open the dash and test the switch it self
Are you still under warranty?
I wouldn't be opening the dash myself...
Solved
I decided to open the dash and see .. It was unplugged wire in the radio .
After car purchase i told them to take it for NAV programming and i left to airport .
I was thinking its amatter of flash USB update but its not , so they didn't box it up properly.
Its working now ..
Thanks to everyone
Its working now ..
Thanks to everyone
Congratulations on finding and fixing the issue!
