Hybrid Technology Unique topics related to the ES300h model hybrid drivetrain and other features/options found only on the ES300h. Please use the main 6ES forum for discussion about shared components with other sixth generation ES models.
My ES300h - 2015 Navigation screen keeps rebooting
Old 06-09-16, 08:49 AM
vbhade
vbhade's Avatar
Default My ES300h - 2015 Navigation screen keeps rebooting
The navigation screen keeps rebooting - Shows Lexus logo then warning message, waits a few seconds and then repeats
So radio, navigation and all others functions are not working any more
Any ideas? do I need to go to dealer?
Old 06-09-16, 08:55 AM
Mike728
Mike728's Avatar
Tons of info on this issue if you just looked around. Need to pull your negative cable for a couple minutes.
Old 06-09-16, 09:42 AM
wdlugitch
wdlugitch's Avatar
Open your trunk, remove the cover to the battery which is on the right quarter, take a 10 mm socket and remote the NEGATIVE battery cable for 5 minutes, replace the cable, replace the cover, start your car, look at your navigation screen and the system will reload. You will be happy................again.
Old 06-09-16, 02:32 PM
vbhade
vbhade's Avatar
This is hybrid model. So I think battery is in trunk. Is it safe to do anything with that battery?
Old 06-09-16, 04:32 PM
SLH
SLH's Avatar
There are two batteries. The 12-volt battery is about the size and shape of a regular car battery. You can safely touch that battery, one terminal at a time, just like a regular car battery.
The high-voltage battery is _much_ larger. The cables that attach to the high-voltage battery are orange. Do not touch that battery, or those orange cables, at all. Technicians take special training, and have special insulated tools, to work in that area.
Old 06-10-16, 11:32 AM
wdlugitch
wdlugitch's Avatar
The only battery you need to remove the cable from the negative terminal from is the one in the trunk, which is a standard 12 volt battery.
Lhduran
01-25-24 02:22 AM
bdallmann
01-14-18 07:24 PM
DunWkg
RX - 3rd Gen (2010-2015)
10-09-13 05:34 AM
NewSC430
12-01-11 10:48 AM
Quick Reply: My ES300h - 2015 Navigation screen keeps rebooting
