2013 ES350 Rear Wheel Bearing
I'm getting a little rumble in my Lt Rear wheel bearing with just over 50k miles. I'm looking online at parts and the part number for the hub/bearing assy is 4246033030. It's showing up as a Toyota part as well.
Does anyone know if the same part matches a Camry or Avalon? The Toyota version of the part is about half of the price. Alternatively, can anyone point me to a good place to get a decent price on this part? It's about $420 on most sites with a list price over $500.
The Powertrain Warranty is for 72 months or 70,000 miles, whichever occurs first. Except for the situations listed on the Basic Warranty page, this warranty covers repairs needed to fix defects in materials or workmanship of any component listed below:
Engine: Cylinder block and head and all internal parts, timing belt and cover, flywheel, oil pan, water pump, fuel pump, engine mounts, engine control computer, seals and gaskets
Transmission and Transaxle: Case and all internal parts, torque converter, clutch cover, mounts, engine control computer, seals and gaskets
Front-Wheel-Drive System: Driveshaft, axle, hub, bearings, seals and gaskets
Talked to the dealer today with no luck. The bearing is part of the 50k mile warranty.
I ordered the part online and will be installing it myself. It's a hub/bearing assembly, so I shouldn't need a press.
Learned a few things I would like to share. First off, I ordered both rear bearings. First one is an OEM Lexus part, $450 online. Second hub/bearing assembly I ordered is a Toyota part with the same sensor/connector. Measured both with calipers and guess what....same part. I'm attaching photos of both parts (Lexus and Toyota) Toyota part was $160. I went ahead and replaced both rear hubs for good measure.
During removal of the first one, I had some trouble removing the wheel sensor wire. In the process, I ripped the wires out - New cable needed . Purchased the cable for $40 and took my time removing the other side. PIA is, you have to remove the rear seat to get to the other end of the wire...
I drove the car for about a week without the wire connected. The following lights illuminate on the dash:
ABS, Traction Control, Brake and BSM doesn't operate. Crazy that all of those are tied to the wheel sensor.
I replaced the wire today, took about 20 minutes including removing the wheel and back seat (bottom snaps in, back requires removal of 4 bolts and lift up and out).
Thanks for posting the bearing replacement details. Could be very useful to other owners.
So you now have a Toyota bearing on one side and a Lexus bearing on the other? Should make a good test to determine if they are of equal quality
