ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Es 350
Old 03-12-16, 06:10 PM
jns
jns's Avatar
Default Es 350
What all is involved with a 100,000 mile dealer service in the Orlando area? Do I have other options that are less costly??
Old 03-15-16, 08:14 AM
Nelexus88
Nelexus88's Avatar
The 100k mile service is fairly basic (see below) with a coolant change being the only extra step. If other scheduled maintenance has not been done prior to the 100k, the dealer will also want to do those items too.
A Toyota dealer or independent shop will be less costly than a Lexus dealer. The least costly option is DIY if you or a friend are so inclined.
120 Months or 100,000 Miles
❑ Replace engine oil with 0W-20 oil;
replace oil filter
❑ Reset maintenance reminder light
❑ Rotate tires
❑ Replace engine coolant
❑ Visually inspect brake pads, calipers and rotors
❑ Inspect wiper blades
❑ Check installation of driver’s floor mat
❑ Road-test vehicle
If you drive primarily under this
special operating condition, perform
these additional items:
Driving on dirt roads or on dusty roads:
❑ Inspect axle shaft boots
❑ Inspect ball joints and dust covers
❑ Inspect engine air filter
❑ Inspect steering linkage and boots
❑ Tighten nuts and bolts on chassis
Old 03-16-16, 01:40 AM
kellens
kellens's Avatar
Consider two other options
1- take it to a Toyota dealer. Can do the service for less, and will still update in the computer you had it done, and use genuine parts.
2- Orlando Lexus over-charges, in purchase and maintenance. Dunno why. Tampa and especially dealers south of central FL are much more competitive and customer oriented.
banjo
12-20-17 06:52 PM
rx11fan
RX - 3rd Gen (2010-2015)
40
05-10-12 06:17 PM
zmanou812
49
04-10-12 11:55 AM
S54toIS350
08-22-06 12:46 PM
billyboy
RX - 1st Gen (1999-2003)
16
04-22-02 05:07 PM
Quick Reply: Es 350
