Home Screen Customization
Hello,
I just recently purchased 5 weeks ago a 2015 ES-350. Previously I owned a 1999 GS-300.
On my home screen I want to have mileage information and cruising range. This is there but it gives mileage since last reset. I'd prefer having mileage since last gas refill. Is there a way to change this?
On that general topic is there a way to clear ONLY the MPG stats? I see the option where I can delete history but what if I want to ONLY clear the MPG stats and have it start over? Is there a way to do this?
If not what is the best way to suggest this for a possible future FW update?
Thanks
Allen
P.S. I should mention that even my old GS-300 had an option to accomplish resetting of lifetime gas mileage independent of the rest of the stats.
Thanks
Allen
You have both Average MPG that is re-settable using the "DISP" display button on right
steering wheel spoke and After Refueling that is not re-settable by you, does itself when
you refuel.
Average MPG then shows up on the Nav Screen under Fuel Mileage with the date that you
last reset it. If left unreset it will accumulate up to 9999 miles then becomes rolling average
of the last 9999 miles.
Resetting History of course removes various graphs that you created. Try resetting the Average
MPG every calendar quarter. Your graphs will then show seasonal results. Try quick resets
when commuting see if you get better MPG into work or going home.
you refuel.
Thanks I was hoping to just reset the mileage counter independent of the rest of the history. On the home screen of the console I was hoping that mileage since last gas refill could be displayed there because it is more convenient than having to scroll to that on the dashboard.
On the dashboard I typically like to have other things displayed. It is all about allowing for the most custom flexibility.
Thanks much
Allen
Thanks much
Allen
