ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Carpet is wet under the front Drivers & Passenger mats.
Old 11-09-15, 10:56 AM
sporty87
sporty87's Avatar
Originally Posted by bc6152
Well, as Art pointed out, there is a leak allowing water to enter the cabin. To me this is a warranty issue and should be corrected free of charge by Lexus. In my opinion you shouldn't have to spend a nickel. Is there no way you can appeal this dealer's refusal to help? Can't you go above the phone agent's level and request assistance? I wouldn't give up just yet but try more complaining and being a PITA. I think that you are being treated poorly.
I have talked all the way to Corporate Lexus and they say it is not covered and won't budge.
Old 11-09-15, 11:20 AM
bc6152
bc6152's Avatar
Received 1,234 Likes on 866 Posts
How about looking into your state lemon Law? Don't know if this issue qualifies, but hey what the heck!
Old 11-10-15, 04:14 AM
sporty87
sporty87's Avatar
Service Manager called back and has the part. I will pick it up this afternoon and give it to the shop that is now working on the car.
If anyone is interested in installing this part here is the part # and name. It has a pesticide in it to keep out bugs and spiders and has a 5 year life.
Toyota Part # 87265-33010
ARINIX TIP
Old 11-10-15, 05:11 AM
Mike728
Mike728's Avatar
ARINIX TIP
If that's the cause of your problem, Lexus would be responsible for the damage.
Old 11-10-15, 06:56 AM
mspearl95
mspearl95's Avatar
i just had this part installed when i had wet carpet, and it wasn't covered. Had to pay for it. It was nowhere near 2500 tho, and my carpets were pulled, dried and disinfected. Final bill was less than half that price, at the dealer.
Old 11-10-15, 07:20 AM
Mike728
Mike728's Avatar
This is an obvious design issue. I'm very surprised they aren't covering it. I would be pissed! Is there a TSB on it?
Old 11-10-15, 07:49 AM
mspearl95
mspearl95's Avatar
Not that I know of, but I bet there will be eventually!
Old 11-10-15, 08:30 AM
jollick
jollick's Avatar
Here is a TSB but it is for Toyota Models. Drain Hose TSB 96210_T-SB-0033-14.pdf
Old 11-10-15, 08:40 AM
mspearl95
mspearl95's Avatar
Originally Posted by jollick
Here is a TSB but it is for Toyota Models. Attachment 373709
I'm surprised there isn't one for the ES. Prob pretty similar to the Avalon, which is on that list.
Old 11-10-15, 08:49 AM
Mike728
Mike728's Avatar
I just did some research. Apparently, this has been an issue for quite a while. There's an old Lexus TSB that states it was covered under warranty at the time. Search: L-SB-0016-10
Old 11-10-15, 09:28 AM
jollick
jollick's Avatar
Here it is
File Type: pdf
Old 11-10-15, 04:00 PM
mrBillFL
mrBillFL's Avatar
that TSB looks like a many of hours labor, and a 1 dollar part.
I've had several cars a/c evaporators backup, and leak living in FLA. But it was always one side, passengers footwell under the dash..
That leads me to think its coming from the windshield/firewall area.
it was just damp but never wet? that could be humidity.
Old 11-10-15, 05:05 PM
mspearl95
mspearl95's Avatar
Mine was wet on all four floor pans, worst on the rear floor pan underneath the front passenger seat. Seems like it'd be a cheap part, but Lexus charged me 170 bucks for it.
Old 11-10-15, 06:13 PM
gregjhonda
gregjhonda's Avatar
Why not just observe to see if their is proper discharge out of the evaporator drain area before doing all the TSB disassembly. You may not be able to access the drain itself but you could at least observe is water is coming out of the drain area.
Old 11-11-15, 09:29 AM
L8RSk8R
L8RSk8R's Avatar
I've had many Lincoln Town Cars leak water. A design flaw where the plastic shroud (where air is drawn in by the blower motor) was sealed with foam stripping.
In a heavy rain, water would seep through the foam & into the cabin via the blower motor.
I had to remove the surrounding shroud, and replace the foam strip with caulking.
I'd be interested to see, how Lexus seal the blower motor shroud.
Quick Reply: Carpet is wet under the front Drivers & Passenger mats.
