ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Tremble when I press my brakes
Old 08-27-14, 10:25 AM
kimjim99
kimjim99's Avatar
Default Tremble when I press my brakes
Hi,
I am a new 2013 Lexus ES 350 owner. I've notices when I'm driving at 55mph and above that when I press the brake when approaching a stop light or stop sign I can feel a vibrations, the steering wheel doesn't vibrate and the car itself doesn't tremble but I can feel it in my foot. My husband said it could be the ABS. has anyone else had the same experience? maybe it's totally normal.
Old 08-27-14, 10:39 AM
Lexusxoxo
Lexusxoxo's Avatar
Sounds like a warped rotor.. That happen on my 2007 ES but I had a lot of miles on my brakes.
Old 08-27-14, 10:44 AM
Arty101
Arty101's Avatar
It sounds like warped rear rotors. If it were the front rotors, you'd feel it in the steering wheel. I doubt its the ABS, otherwise, you'd get a warning light.
Have the dealer look at it. It may be under warranty or they may do a customer accommodation. Good luck.
Old 08-27-14, 12:16 PM
bc6152
bc6152's Avatar
Received 1,231 Likes on 864 Posts
Had the same issue with an Avalon. The rotors had to be recut (smoothed out) as they had warped unevenly. You feel it shuddering thru your foot.
Old 08-27-14, 03:01 PM
Nelexus88
Nelexus88's Avatar
The rotors may be warped or have uneven deposits from the pads. Either one is cured by machining (1 time) or replacing the rotors. Hopefully its still under warranty.
Old 09-03-14, 08:03 AM
kimjim99
kimjim99's Avatar
Thank you everyone, I'm going to have it checked out.
Old 09-03-14, 11:04 AM
larrytstar
larrytstar's Avatar
I have a 2013 ES. I had to have the dealer turn the rotors at 10,000 miles to fix the kind of vibration you mention. Good luck.
Old 09-04-14, 10:03 PM
Arty101
Arty101's Avatar
Be aware rotors are getting thinner to save on weight. That said, there's a limited times you can true your rotors. One major cause of warped rotors are over tightened or improperly torqued wheel bolts which hopefully shouldn't be from the manufacturer or dealer. Just a thought.
JDMis350
10-07-12 12:54 PM
DaytonaSTi
06-17-10 02:30 PM
Shawnmack
RX - 1st Gen (1999-2003)
19
09-11-07 12:24 PM
DaJark
Suspension and Brakes
10-16-06 06:16 PM
99LexusES300
11-24-02 10:49 PM
Quick Reply: Tremble when I press my brakes
