Going from Navigation Screen to Pandora faster - Is there a way?
Is there a way to navigate quickly to Pandora from the Navigation Map Screen?
I've not found a way to quickly get back to Pandora when it is playing a song from the Navigation Map Screen. If you press the Radio button on the dash it takes you to the last item I used like SAT radio or FM radio. If you press the Media button on the dash it takes you to the USB stick I have installed.
Press Radio ONCE from the Nav Map and it will stay on "Apps" with a button to jump directly to Pandora in the bottom left.
If you still can't get it to work, press the Home button near the mouse, then click on Radio. You will see the same "Apps" page.
Thanks @foganime! I thought I tried that and it did not work that way. Worked great by pressing the Radio button.
Too bad there is no Voice Command to take you to Pandora.
dbs600
07-01-16 06:09 AM
