ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
2013 ES bluetooth question
Old 04-05-14, 07:00 AM
mrtnd0000
mrtnd0000's Avatar
Default 2013 ES bluetooth question
I have a customer who is experiencing some difficulty with his bluetooth.
The car is a 2013 ES350 and the phone is a Droid phone with Verizon service.
Customer is claiming that the phone keeps disconnecting and reconnecting from bluetooth on its own, sometimes several times per commute and sometimes to the point where he has to reconnect himself.
any thoughts on why the connection would be interrupted like this?
thanks in advance,
matt
Old 04-05-14, 07:20 AM
Cerulean99
Cerulean99's Avatar
I have an iphone and have not had any problems with connections, so it's likely not the car. Lexus seems to favor the iphone over android since they have siri talk free and no android equivalent.
Old 04-05-14, 07:27 AM
jim256
jim256's Avatar
thanks in advance,
matt
Delete and re-pair, and watch for a pop-up on the phone that says something like "connect automatically each time"....it comes up after the pairing, and also at car restart, but unless you are watching the phone you will not see it. I've had several Android phones (recently MotoX and Galaxy Nexus) with no problems, and several on other Lexus/Toyota variants. Some, however, were sensitive to phone/antenna location--back pocket was sometimes a problem.
Old 04-10-14, 09:28 AM
hebdo27
hebdo27's Avatar
No problem here with Galaxy NOTE 3 or NOTE 2. Probably a phone setting that he needs to enable (automatic connect setting) so that the phone doesn't require you to confirm the connection each time.
Old 04-10-14, 09:32 AM
amphipri0n
amphipri0n's Avatar
Maybe an option on the phone is enabled for power conservation "Turn off BlueTooth after XX minutes idle" ? Which is pretty useless now since the latest version (which the ES supports) of BT is very efficient
Old 06-07-14, 11:03 PM
mrbrown188
mrbrown188's Avatar
I'm having this problem in my 2014ES. Will try and look for the setting Jim256 is talking about.
Old 06-09-14, 07:03 AM
mackbuck12
mackbuck12's Avatar
I'm having the same problem with a Samsung Galaxy 3.
Old 06-09-14, 09:50 AM
bootman
bootman's Avatar
Even after deleting and repairing?
Old 06-09-14, 12:34 PM
MissyBissy
MissyBissy's Avatar
I posted a thread about this - after the stupid kitkat update my Bluetooth did this. I had to have the phone and car forget the Bluetooth connection and then reconnect. It stopped connecting and disconnecting but I still can't get my car to read me my text messages. First world problems
Old 06-17-14, 05:29 AM
mrtnd0000
mrtnd0000's Avatar
this seems to be the solution so far. it did work and havent had any problems with it since so we arekeeping our ifngers crossed. Thank you for all of the responses
Old 06-25-14, 11:09 AM
ChuckNorri
ChuckNorri's Avatar
Default constantly disconnecting & reconnecting bluetooth
I have the same issue with my Galaxy S4 since the 4.4.2 update.
Old 06-25-14, 12:13 PM
jim256
jim256's Avatar
4.4.2 on the Moto X works fine, went through the upgrade from .1.
srican
ES - 5th Gen (2007-2012)
07-07-15 07:53 AM
Adamjeeps
05-17-12 07:42 AM
Yaff
03-13-12 09:57 AM
Xanadu350
04-16-11 03:35 PM
OutCaster
02-15-08 05:50 PM
Quick Reply: 2013 ES bluetooth question
