ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Side moldings DIY: is std. location too low to protect from dings?
Old 02-26-14, 04:51 PM
Canesguy
Canesguy's Avatar
Originally Posted by Poppa
I think I finally was able to figure out how to post a pic on this forum..... here's a pic of my ES with the body side moldings...
I likey. Did you do it or your dealer?
Old 02-27-14, 02:08 AM
Poppa
Poppa's Avatar
They were dealer installed...
Poppa
Old 02-27-14, 04:34 AM
bc6152
bc6152's Avatar
Received 1,236 Likes on 868 Posts
If anyone requires the factory instructions on how to install the side moldings, I have them available. I agree with those that say they're not 100% protection, but are still a safety barrier against the inconsiderate morons that ding your doors.
Old 02-27-14, 05:02 AM
Arty101
Arty101's Avatar
Originally Posted by SW13GS
I've noticed that when the molding is installed in such a way that it slopes downward towards the front as it does in Poppa's thread, it looks better and follows the lines of the car better. If you look at the 4GS Joe posted with the moldings further up in the thread, they are just parallel to the ground and really look tacked on IMHO.
I think the sloping down appearance is more due to the camera angle and prospective. The sloping down is actually no more than about 1/2 inch front front to rear on the front door. But I still think it looks good.
Old 02-27-14, 05:40 AM
bc6152
bc6152's Avatar
If I recall correctly, when I installed my moldings they were level. Not sloping up or down.
Old 02-27-14, 05:50 AM
Arty101
Arty101's Avatar
Sounds about right since a 1/2 inch is +/- , and my bad eye sight .
Old 02-27-14, 05:54 AM
Received 2,520 Likes on 1,818 Posts
No its more than that, I see the difference in person. It may be that the instructions from the factory are what don't look right to me.
Old 02-27-14, 09:30 AM
arlinek
arlinek's Avatar
Poppa: that looks so nice! My car is also the Matador Red. It's funny, others mentioning about a slight slope as it is something I was wondering if I could do as I like it, also. (I don't really notice it on Poppa's car.) Anyone know the measurements (for placement) if one wanted to do it so it "looks" right? But, just in case, Poppa: Could you tell me the height from bottom of front door to the bottom of the molding and the same for the rear door and if YOU think the molding IS at a slight angle by measuring the beginning and end of the rear molding on each door - would that be too much trouble? I understand if it is ... or, does anyone else know what the placement dimensions should be if one wants to put them at a slight angle?
Old 03-01-14, 02:31 AM
Poppa
Poppa's Avatar
arlinek.... I'll try to remember to get those measurements for you tomorrow ( saturday ). Sorry I don't have them for you now, but I just now read this post.....
Poppa
Old 03-01-14, 11:53 AM
arlinek
arlinek's Avatar
Thanks so much for the trouble, Poppa!
Old 03-06-14, 10:29 AM
bc6152
bc6152's Avatar
Here are the factory measurements. If you wish to deviate from these
- which I do not recommend - you would adjust the door bottom mm to a lesser number. IMO if you change the positions it would appear that it was incorrectly applied. The photos in the previous posts were those of a dealer installed set of moldings. NO deviation up or down.
Old 03-07-14, 03:16 AM
Poppa
Poppa's Avatar
Poppa
Arlinek..... I'm so sorry I didn't get back to you with the measurements on the body side moldings.... and unfortunately I have misplaced the paper I jotted the numbers down on. But I do remember for a fact that the distance from the bottom of the moldings to the bottom of the door, were the same at the front and back of the moldings... there is no slope forward... I think it's just the angle of the picture I took of my car.... they were dealer installed.... I actually like the look of the moldings.. I don't know if it has anything to do with the color of the car, but the moldings ( which I normally don't care for on a car ) look pretty nice to me on this car... again, they are not the "perfect" protection to door dings, as some jerk has already "dinged" my passenger rear door. It's not bad, but it still pisses me off. Even so I think they provide some protection, and certainly are better than no protection... Just a question of whether or not people like the look of them on their car.... hope this helps.
Poppa
Old 03-08-14, 12:11 AM
arlinek
arlinek's Avatar
Thanks, Poppa. If you had to do it again, would you have the identical placement ... or do you think in hindsight that a little higher up might have been better? I'm just concerned since the normal placement based on Lexus' written directions are below the area of the widest point on the doors.
arline
Old 03-08-14, 07:04 AM
Higher up would really look odd...
Old 03-08-14, 09:38 AM
Arty101
Arty101's Avatar
Steve, you were never enamored with any side molding LOL.
Quick Reply: Side moldings DIY: is std. location too low to protect from dings?
