ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
turn off AC without going to MENU?
Old 01-31-14, 03:11 AM
Poppa
Poppa's Avatar
Originally Posted by nakago1
Thank you for all the replies.
what I wanted to know originally was if there is a Way to turn the AC off only, leaving the FAN on. sure if i press the "off" button it would turn off AC and FAN, the ambient air flow is too weak to my liking, i like to have FAN on but AC off, which i cannot find anyway to do except to go through the three step i described .
This kind of leads me to my question.... how do you just bring in outside air and use the fan, but not turn on the a/c. Example, I'm driving home from work tonight and the outside temp was around 60 degrees, but it was a little warm in the car... I pushed the button that shows a picture of what appears to be "outside" air coming into the car, but to get the car cooler, I still had to turn the temperature down.. seems to me if I was truly running just a ventilation system, that 60 degree outside air would have been plenty cool, but it wasn't... I know I'm just doing something wrong .... but I did find an alternative way of getting the cool air inside... I rolled down a window.
Poppa
Old 01-31-14, 06:48 AM
jim256
jim256's Avatar
The temp setting will dictate the temp, and warm, or let in outside air- to the extent that it can without the compressor, to reach a cooler temp setting. This is pretty much how every car I've had with auto temp works. No different than a manual heater system, where you rotate the temp wheel to off when you just want outside air. All air still goes thorough the heater core and will warm it if that's what you want, or it will just let in outside air. You need to turn down the temp setting if you're hot.
Old 01-31-14, 07:33 AM
ilexusown
ilexusown's Avatar
Originally Posted by jim256
I think what the poster is saying is that, at speed, there will still be ambient air forced through the system. It likely stays at the last temperature setting relative to the outside air. If it's 40 outside and was set at 70, the air coming through will still be heated, if it's 80 outside, but the last setting was 65, you're not going to cool it but you'll get ambient air. Makes sense as much as anything would--it has to default to something while it still maintains some airflow for CO build-up prevention. If you want it really "off", also press Recirc.
Yes, that is exactly what I am saying. Thanks for stating it better. My point is that when I turn "off", I really do not want the ambient air to go through any system. It should be the air temp from outside, similar to opening the window. BTW, what is Recirc?
Old 01-31-14, 07:53 AM
jim256
jim256's Avatar
The only way air gets inside the car ducting is to go "through the system". Recirc is recirculated inside air (about 20% fresh from outside) by pressing the button that has 3 lights--recirc, fresh, auto with a graphic showing the air pattern. I think you really need to read the manual or revisit the delivery specialists at the dealer.
Old 01-31-14, 01:30 PM
amphipri0n
amphipri0n's Avatar
20% fresh in recirc? Really?
Old 01-31-14, 04:50 PM
sgmstr
sgmstr's Avatar
Hi Guys,
There is a thread about this on 4Gen GS.
https://www.clublexus.com/forums/gs-...-c-button.html
Originally Posted by XBimR
Not the one in the menu, but a way to turn the A/C on and off via physical button. Some of you may know this, figured I would post for those like me who missed an actual A/C button.
Right under the hazard button is the button for fresh or recirculating air, with an "auto" in the middle. I had always assumed this worked with the main auto setting, which it does. However pushing it multiple times will also turn off and on the A/C! Try it out. Yes, I am excited about this as this was one of the few things that annoyed me about the car.
Old 02-01-14, 06:15 PM
Poppa
Poppa's Avatar
does anyone knows how to turn off AC without going to
MENU - Climate - move cursor down to "AC" and click it off. (3 steps)
anyone figure out how to this in less steps? i find it a real hassle. most cars have "AC on or OFF button"
Took my car over to the local Lexus dealership to get her washed.. while there I asked one of the service writers about this because, like nakago, I would like to pull in outside air using the fan but not using the compressor... I was pretty much told the same thing... have to go thru the nav, to climate and then click on the ac tab to shut the compressor off.... I was also told that I should normally run my climate control ( heat and ac ) with the "recycle air" button on... I was told it was easier on the system... anyone heard this before?
Poppa
Old 02-02-14, 02:47 PM
ElliotB
ElliotB's Avatar
This doesn't answer the question directly but you can get the a/c on without having to go through the menus if you have the default setting to off for the compressor. If you press the front defrost button, the a/c comes on but the air is distributed to the front windshield, your feet and the two outside vents. It does not stay on if you change to another setting like AUTO. Although it may not be considered 'necessary' to have an a/c on/off button, it would have been nice (perhaps).
Old 02-03-14, 03:28 PM
jakepdx
jakepdx's Avatar
sgmstr, FYI I just tried the multiple presses of the Auto button for fresh/recirc while the Climate screen was on the display, and no matter how many times I pressed it the A/C stayed on. So it doesn't seem to work on my 2014 ES 300h.
Old 02-03-14, 03:30 PM
lesz
lesz's Avatar
Received 1,017 Likes on 695 Posts
It doesn't work on my 2013 ES350, either.
Old 02-03-14, 03:35 PM
sgmstr
sgmstr's Avatar
sorry, guys. Weird set up by Lexus.
Old 02-03-14, 04:02 PM
Halfmoon
Halfmoon's Avatar
Ours either
Old 02-03-14, 04:25 PM
ElliotB
ElliotB's Avatar
If anyone is interested, you can adjust the a/c to stay on or off manually by going to the Vehicle Customization Menu, and change the Auto A/C setting to OFF in the Climate Control section to be able to leave the a/c on or off manually (and keep it on or off).
I tried the tip mentioned above and it worked in my car (300h). I do have the Auto A/C setting to off - I don't know if that makes a difference. The a/c is on when the left and center lights are on.
Followup:
I did a check and the control works regardless of the Auto A/C setting.
Old 02-04-14, 09:50 AM
Universe93
Universe93's Avatar
Here's a thread on this issue before and some useful info:
https://www.clublexus.com/forums/es3...dashboard.html
Old 02-04-14, 12:12 PM
mcomer
mcomer's Avatar
Remember that conventional A/C compressors are belted to the engine and operate at widely varying speeds, too slow at engine idle and way to fast at highway speeds. Inefficient and hard on the hardware. Our Hybrids are powered off the 244v battery and run at exactly the design RPM. While it makes sense to cut off the compressor of a regular IC car to save fuel / $ / noise it should not be as dramatic an improvement for ours.
Let's run a few empirical tests using the average MPG resets and let the trip graphs tell us!
Quick Reply: turn off AC without going to MENU?
