ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Odd temperature range for Heating and AC
Old 01-29-14, 10:33 AM
hebdo27
hebdo27's Avatar
Default Odd temperature range for Heating and AC
I've been enjoyiny my new 2013 ES300h for the last 3 months and recently noticed that the auto temp settings go from 18 C to 32 C. I find this very odd as in the summer I would very much like it to be cooler than 18C and in the winter it would be extremely uncofortable to keep the termostate past 28C (once the car has warmed up). Anyone else think this is odd or just me? I'm in Canada and have a Canadian ES (made in Japan), not sure if the US version is different with a different range.
Old 01-29-14, 11:16 AM
Tpcorr
Tpcorr's Avatar
That range, if I remember my metric conversions right, is about 65 degrees Fahrenheit to 90 degrees Fahrenheit. I'm not in my car right now, but I'd bet dollars to doughnuts that the range in my American ES is the same.
Tom
Old 01-29-14, 11:26 AM
lesz
lesz's Avatar
Received 1,010 Likes on 691 Posts
I believe that 65 degrees F is the same minimum low setting on every vehicle that I've owned with an automatic climate control system. I don't recall what the maximum has been on other vehicles, but I can't imagine ever wanting temperatures of even close to 90 degrees F.
I also believe that, if you are using the AC and set the system to the lowest possible temperature, what happens is that the AC runs continuously and with the fan at the highest setting, and, thus, it will give you actual temperatures lower than the lowest stated setting. Similarly, when you are using heat and set it to the highest possible temperature, it will run the heater constantly and with the fan at the highest setting, and, thus, it will give you actual temperatures hotter than the highest stated setting.
Old 02-04-14, 09:11 PM
hebdo27
hebdo27's Avatar
I was asking as my other car, a Honda Accord 2011 has a much more reasonable temp range. (16C to 28C). Thus I can set it to 17 C and the AC will not be constantly running. No biggy but just something I noticed. Again I've only had this car for 3 months so don't really know how it will be once the AC is used.
fiddler1
12-09-16 09:47 AM
Marcust99
40
08-18-13 08:08 AM
rxsuperman
RX - 3rd Gen (2010-2015)
13
10-16-11 09:26 AM
Toofasgtp
01-02-11 01:24 PM
MikeP
ES - 5th Gen (2007-2012)
07-06-10 03:19 PM
Quick Reply: Odd temperature range for Heating and AC
