ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Rear suspension absorbs bumps poorly ?
Old 01-15-14, 10:41 AM
  #46
Received 2,499 Likes on 1,802 Posts
Don't overthink the tire pressure. Just lower the pressure to 31 or so cold...meaning after the car has sat and hasn't been driven. Pressures will fluctuate up and down some depending on the temps...don't sweat it.
Buy yourself a nice tire gauge and have at it.
Old 01-15-14, 10:44 AM
  #47
lesz
lesz's Avatar
Received 1,010 Likes on 691 Posts
Originally Posted by pmarder
I want to lower the psi even more in order to improve the ride but I am confused when to do so. By way of example, this morning it was in the high 40's and when I started my car, the tire pressure system showed my front tires to be 33 while the rears where 34. After driving the car for half an hour and reaching my destination, all four tires read 36 psi. So the question is, do I want the tires to read 33 psi after being warmed up or 33 psi when I start (which would mean that I should leave them be)? Thanks for the help.
Tires should always be inflated before driving and before they get heated up from driving.
Old 01-15-14, 12:14 PM
  #48
jim256
jim256's Avatar
While I generally love my new 2014 ES, I must admit to being very disappoint with the firm ride. Coming from a 2005 ES330 (which I adored), I had grown to being used to a car with a comfortable and compliant ride. Instead, I find my new ES to transmit every bump and at times be almost jarring. The car originally was fitted with Bridgestone tires which I had swapped out for the Michelins. Those tires appeared to be over inflated at 38 psi when I received the car at which point the dealer reluctantly agreed to lower the pressure to 35. I want to lower the psi even more in order to improve the ride but I am confused when to do so. By way of example, this morning it was in the high 40's and when I started my car, the tire pressure system showed my front tires to be 33 while the rears where 34. After driving the car for half an hour and reaching my destination, all four tires read 36 psi. So the question is, do I want the tires to read 33 psi after being warmed up or 33 psi when I start (which would mean that I should leave them be)? Thanks for the help.
33 when cold, standing for several hours, where it is normally located.
Old 01-15-14, 02:38 PM
  #49
pmarder
pmarder's Avatar
Thanks for all the advice. I would therefore assume that based on my example from this morning that the tires are at "spec" and shouldn't be adjusted. Is that correct? Either way, I'm thinking of taking SW13GS's advice in the hope of improving the ride. I assume the worst case scenario is that my tires may need to be replaced earlier than anticipated. Again, thanks everyone. This board was invaluable when he came time to purchase my car.
Old 01-15-14, 06:45 PM
  #50
jonmanch
jonmanch's Avatar
They should be 33 when they are cold; first thing in the morning or when the car has not been driven for awhile.
rmbthird
GX - 1st Gen (2004-2009)
11-08-17 05:23 AM
CobraGSF
02-29-16 07:57 AM
ngerstman
RX - 3rd Gen (2010-2015)
01-23-14 02:50 PM
looknow12
05-03-03 07:50 PM
blessedbigtime
08-22-02 12:05 AM
Quick Reply: Rear suspension absorbs bumps poorly ?
