ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Splash Guards
Old 05-08-15, 11:25 PM
  #61
Arty101
Arty101's Avatar
Bob, did you ever install the rear mudguards? Painted?
Old 05-09-15, 06:34 AM
  #62
bc6152
bc6152's Avatar
Received 1,236 Likes on 868 Posts
No Art, I bought the black ones from Ebay right after I got the car back in early 2013. A friend also has a Satin Cashmere 2012 model and installed the car color mud guards. After seeing his I liked the contrasting black more so I didn't paint them. They're still on there and still look good. I armorall them each time I wash the car so that they have a satin shine. I did install the rears and they installed easily and look perfect.
Old 05-15-15, 05:37 PM
  #63
mrBillFL
mrBillFL's Avatar
Did you need to drill through metal or just plastic?
did you use any sealant for the screws?
Old 05-16-15, 05:24 AM
  #64
bc6152
bc6152's Avatar
I drilled through the plastic bumper/rear panel to mount the mud guards. I used stainless screws and washers to eliminate rust. The installation was simple and it took me about 15 minutes for both sides. I did not have to remove the wheels.
Old 05-21-16, 02:49 PM
  #65
imrankh24
imrankh24's Avatar
Can you please post a DIY on how to install the rear and what drill size to use? Thank You very much!! Planing to install today
Old 05-21-16, 05:30 PM
  #66
bc6152
bc6152's Avatar
I was planning to take some photos but today in PA is teeming rain. Probably across the river too.
I'll do it when the weather clears.
Old 05-21-16, 08:22 PM
  #67
imrankh24
imrankh24's Avatar
Thanks here in jersey it was raining quite a lot to do I postponed it to tomorrow! Overall was it hard and do you need more hardware then the screws provided?
Old 05-22-16, 04:58 AM
  #68
bc6152
bc6152's Avatar
Just the screws and a drill. Mine have been on for almost 4 years.
Old 05-22-16, 06:45 AM
  #69
imrankh24
imrankh24's Avatar
Alright sounds easy so I put the guard in place with the bottom nut and drill the provided screws through the guards and done? Sounds easy
Old 05-22-16, 07:06 AM
  #70
bc6152
bc6152's Avatar
It really is a simple install. Try to use stainless screws and a stainless washer = no rust...I used a 1/8" drill. After securing the top and bottom screws I painted the screw heads with some flat black paint and they're invisible. Let us know how you make out.
Good Luck with the project!
Old 05-22-16, 07:14 AM
  #71
imrankh24
imrankh24's Avatar
Thank you very much I will attempt it today!
Old 05-22-16, 04:17 PM
  #72
imrankh24
imrankh24's Avatar
Ok so I successfully installed all 4 guards and I used a 1/8 drill bit for the back as you said worked perfectly!!
Attached Thumbnails Splash Guards-photo416.jpg   Splash Guards-photo321.jpg   Splash Guards-photo827.jpg   Splash Guards-photo598.jpg   Splash Guards-photo37.jpg
Old 05-22-16, 04:34 PM
  #73
bc6152
bc6152's Avatar
Nice job! Looks great and glad to help. Car is beautiful, too bad Jersey makes you put a tag on that pretty grille.
Old 05-22-16, 05:10 PM
  #74
imrankh24
imrankh24's Avatar
Yea hopefully one day it changes I wanna take the plate off as well, Thanks bro!
Old 05-22-16, 07:36 PM
  #75
imrankh24
imrankh24's Avatar
Do you know how to remove pictures from a post?
Quick Reply: Splash Guards
