ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Tires - Proper Inflation
Old 05-15-13, 04:55 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Originally Posted by ElliotB
"For the best mix of handling, fuel economy and tire longevity, in general, use what the manufacturer of the vehicle recommends. "
The ES 300 comes with one of two types of tires, Michelin or Bridgestone. The he Michelin's have a lower maximum tire pressure rating In the Bridgestone's, So the recommended pressure may be good for one brand , but not both.
Actually, maximum pressure has nothing to do with max pressure listed on the sidewall. All P-Metric tires carry their maximum load at 35 psi and all euro metric tires do the same at 36 psi I believe, aside from XL rated tires, which are 41 or 44 psi, as listed on the sidewall. So, lets say we have a Michelin tire with a 35 psi maximum pressure and a Bridgestone with 50 psi maximum pressure. We inspect the door placard and both tires are the same as original size (including p-metric, euro-metric, LT, etc) and the door says 32 psi. It doesn't matter which brand tire is on the car or the tires maximum air pressure, Lexus recommends 32 psi. The reason some tires have higher maximum pressures is not to carry extra weight (in these passenger car style tires at least), but to tune how the vehicle and tire handles... higher pressure generally reduces tire roll during a turn and a change in air pressure can dramatically change how a tire handles.
Originally Posted by scutmud
I had learned that as long as you have the correct tire size the pressure in the tires should be what the car manufacturer recommends on the sticker they put in the door jams
Old 05-15-13, 08:30 PM
lexo98
lexo98's Avatar
MItsuguy's right. I sell both Michelin and Bridgestone tires. Im not sure what tire models, size and load ratings you are running on your vehicle. Basically if the Michelins on your vehicle are the exact size and load ratings as your door sticker it would probably be in your best interest to use the OE settings. Now if the sizes are the same and the load ratings are different there maybe some adjustments in the air pressure required for the vehicle to carry the same load as intended.
pc1990
IS F (2008-2014)
19
07-06-21 11:20 AM
Biologist
05-24-13 01:45 PM
mitsuguy
Wheels, Tires & Brakes Forum
06-06-09 12:52 PM
daryll40
01-19-07 05:05 AM
Quick Reply: Tires - Proper Inflation
