ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
2008 Lexus ES 350 transmission fluid capacity
Old 03-21-17, 11:46 AM
xnguyen002
xnguyen002's Avatar
Default 2008 Lexus ES 350 transmission fluid capacity
How much transmission fluid capacity for 2008 Lexus ES 350
Old 03-21-17, 07:45 PM
dreyfus
dreyfus's Avatar
I'm not certain of the actual capacity, but I used all 12 quarts when I swapped out my ATF 95,000 miles ago. It's expensive stuff.
Old 03-22-17, 07:46 AM
Clutchless
Clutchless's Avatar
Received 1,097 Likes on 936 Posts
Here is a link to the information from the Toyotanation forum on the Camry which has the same transmission. http://www.toyotanation.com/forum/10...fo-sticky.html
It also has many other maintenance tips.
Old 03-22-17, 03:36 PM
ESh
ESh's Avatar
The capacity is 6,94 qt.
I used 12 qt too but I did it through the return pipe.
Old 03-24-17, 06:06 PM
chuyrobles
chuyrobles's Avatar
I don't mean t doubt you, but it's gotta be more than 7 qts. I used a pump, also through the return line, to pump ATF into the transmission while the trany pumped out the old stuff. The ATF didn't start to look pretty in red until about 10 qts and I continued flushing until I had flushed out about 11.5 quarts. Then leveled it out with a temp gun, then added 200ml at the end as the book recommends.
Old 03-25-17, 06:07 AM
hypervish
hypervish's Avatar
Just looked it up in the repair manual, apparently the fluid capacity is very low on these.
PERFORMED REPAIR/ FILL AMOUNT
Replacement of transaxle (a new torque converter is used) : 5.3 liters (5.6 US qts, 4.7 lmp. qts)
Replacement of transaxle (the torque converter is reused) : 3.4 liters (3.6 US qts, 3.0 lmp. qts)
Removal & installation of oil pan (including oil drain) & Removal & installation of drive shaft : 2.8 liters (3.0 US qts, 2.5 lmp. qts)
Removal & installation of valve body : 3.2 liters (3.4 US qts, 2.8 lmp. qts)
Removal & installation of torque converter : 4.8 liters (5.1 US qts, 4.2 lmp. qts)
Repair of oil leakage and removal of oil cooler and cooler hose : 0.5 liters (0.5 US qts, 0.4 lmp. qts)
overclock (10-07-20)
Old 03-25-17, 04:52 PM
chuyrobles
chuyrobles's Avatar
Oil cooler? Our 07 don't have one, unless it's referring to the ATF fluid reservoir in the radiator. But, you can't remove the reservoir from the radiator.
How do you add all that up when flushing through the transmission-radiator lines? I flush till the ATF color starts to look translucent red. Or, about 11-12 quarts.
Old 03-25-17, 10:47 PM
dreyfus
dreyfus's Avatar
No, but you can remove the outflow line to the radiator. That's what I did, measuring and replacing all the fluid pumped out (about two quarts at a time) until it looked like new fluid.
bkennedy39
ES - 6th Gen (2013-2018)
29
08-18-19 02:13 AM
Accolade75
03-30-18 11:37 AM
tomiv9
06-05-15 12:33 PM
rmd5062
Build Threads
07-17-13 12:58 PM
Quick Reply: 2008 Lexus ES 350 transmission fluid capacity
