2007 es 350 A/C vent issue
The driver side only blows hot air, the passenger side is fine. I believe a vent is stuck open. How can I repair. I cant seem to find a vent diagram online.
Have you tried cycling through all the air direction settings to see if it changes or possibly loosens up the vent damper? Do you have dual a/c settings? Are both sides set to the same temp?
Check the Expansion valve or Core evaporator???
From a same model:
EXPANSION VALVE ~|~SEE
HISTORY,AC BLOWS HOT OUT DRIVERS SIDE ,A LITTLE COOL FROM RT SIDE ~|~PARTS WARRANTY ~|~173020 DEFECTIVE EXPANSION VALVE 883601 64/50 FPN: 88515-33020 140 DEFECTIVE EXPANSION VALVE, FREON LINES UNABLE TO SEAL PROPERLY, REPLACED EXPANSION VALVE, AND ORINGS, ALLOWED 12 HOURS TO PASS CHECKED FOR LEAK AGAIN, EXPANSION VALVE FITTINGS NO LONGER LEAK
From a same model:
