ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
XM antenna on radio
Old 04-30-16, 02:03 PM
seawind300
seawind300's Avatar
Default XM antenna on radio
Hi again, I'm looking for the sat antenna connection on the back of the radio/nav unit. Anyone have a pdf of the unit?
Thanks, Mike
Old 04-30-16, 02:49 PM
nevernu
nevernu's Avatar
maybe around page 11 it shows the tuner cable and antenna cable connections?
File Type: pdf
Old 04-30-16, 03:24 PM
seawind300
seawind300's Avatar
So is this saying the sat receiver is in the trunk? If so, then there must be a wiring bundle going to the nav unit, not an antenna hook up.
Old 04-30-16, 05:15 PM
nevernu
nevernu's Avatar
the sat tuner is inside the right rear trunk panel forward of the amp. sat tuner wiring uses the amp harness. Take the panel off and the connections, diagram will seem clearer.
Old 05-04-16, 08:02 AM
seawind300
seawind300's Avatar
there is no unit ahead of the amp in the right side of the trunk.
Davidsofia
05-15-18 04:14 PM
Slat
08-28-13 07:45 AM
TLRD
07-03-13 07:36 PM
MMS4MSU
06-01-11 02:11 AM
vasco
04-19-06 07:03 PM
Quick Reply: XM antenna on radio
