My latest rims - third time is the charm.
Nexen 235/40-19s, $136/tire. Here is the description from Tire Rack's website where I ordered them from:
"The Classe Premiere CP671 is Nexen's Grand Touring All-Season tire developed for sedans, coupes and compacts. Designed for all seasons, Classe Premiere CP671 tires combine a quiet, comfortable ride with all-season traction in dry, wet and wintry conditions, even in light snow.
The all-season tread compound of the Classe Premiere CP671 is molded into a symmetric block design with broad shoulder blocks and a continuous center rib to promote cornering and directional stability. Four straight wide grooves channel away water to avoid hydroplaning and maximize traction on wet roads while lateral grooves and multiple sipes enhance starting and stopping capability in foul weather.
The tire's internal structure includes twin steel belts reinforced by spirally wrapped nylon on top of a polyester casing to combine strength and durability with ride comfort"
Thanks! They were D2 and I believe it was the RS series (I installed these several years ago). Here is a product blurb from D2's website:
"The RS Series suspension kit is our most popular coilover. Featuring a 36-way damping and rebound adjustable monotube design, RS Series coilovers are perfect for the modified street car that also sees occasional track days. This coilover has separate height and preload adjustments allowing for optimal suspension tuning while maintaining full strut travel at all times.Features:36-way damping adjustable monotube shock assemblies. Full ride height adjustability with separate spring preload. Anodized finish and Teflon coated threads to prevent rust. Upper camber plates and pillow ball mounts* (6061 Aluminum construction)1 Year Manufacturer’s Warranty. Serviceable in the USA
baddis es
Wheels and Tires Classifieds
16
07-01-12 01:05 PM
Lexatlast
GS - 1st Gen (1993-1997)
25
07-02-09 02:19 AM
PhilipMSPT
02-05-06 05:09 PM
