How many KM do you get per tank?
If you're getting 11.9 L/100km, then you're doing about average especially for Ontario. How much fuel do you actually put in? The fuel tank holds 70 litres. I usually fill only about 55 litres, but my low fuel warning light is usually on at that point. Means I still could have driven for quite some time. Lexus gives you a lot of warning before you're actually on empty.
how come other people are getting 500+average and i'm getting so low? im thinking i take it in for spark plugs and o2 sensors
You should scan it first, use Techstream.
Are you using premium fuel? I know that can make a difference. On my 02 Maxima I would loose ~100km/tank when using regular vs. premium. So when I recently bought my 08 ES, I've just stuck with premium as it recommends it for this year.
i use to use premium and used it for about 10 fill ups in a row and was getting about 20km more only so i stopped because the the es350 uses the same engine as the toyota camry and camry can take 87
That's the best scanning tool for Toyota. On aliexpress for $15.
I have the same year and it is scary strange that you have this low of km per tank, i average around 650km and the lowest was around 550km, probably in winter. One time, i even got some 725km per tank but it never happened again for some reason.
2. do u use 93gas or 87 regular? 3.how many KM do u have on ur car? 4. whats your KM per litre reading on your menu? mine is 11.9km
5. also where in canada do you live as i'm from toronto its mostly city driving here
1. are you getting those numbers from pure highway driving or mixed city/highway?
2. i use 93 octane
3.250 000km, maintenance A1,
4. I've tested the mileage by ready the menu AND also by calculating the number of km per gas fill-up, i get around 1 L/100k better while calculating vs the menu on the car. On the menu of the car, i get around 9.1 L/100km, sometime 11.9, but i get more than 400km per tank.
5. i'm in montreal, quebec. And yes you may point something important, if i do 100% city, i get around 13 L/100km.
6. i do have a heavy foot.
Twice, i notice that my brake piston was stuck and grinding my rotor, but heard no noise, that eat up my mileage.
Has do done all the proper maintenance, cleaning the engine air filter ?
1. my numbers are around 20% city 80% highway (120km/hr)
2. i use 93 octane
2. i use 93 octane
so my last reading i got 468KM on a full tank. with 11.7l/100km
this was from 87 regular gas half, and half 93
i can never seem to even get 500km and all of you get 700, not sure what is going on here bud
I think there's a problem. If your consumption is 11,7, that means with 70 liters you can go 600 km.
When you fill the tank, do you stop it after the first click or you continue filling? You can add around 6 liters after the first click.
Yes, i see the problem, in theory you should get 600km. Something nmay be wrong with the display calculation.Lexus081, did you use the odometer to calculate your fill-up and how km can you get ?
>>Something may be wrong with the display calculation.
you know you can reset the display calc to re calibrate by pressing down the display button for several seconds
hisstojay (11-02-17)
i stop filling after the first click because, ignorantly, i thought they fill to max capacity but i guess not.
so 70 litres is the max capacity for the 2008 es? ?
and yes, i reset my display already and yes, i reset the trip meter
Yes, empty to full, around 72, but only if you keep pushing the fuel until you see it next to the cap.
