2011 ES 350 3rd tail light removal
When hitting the brakes, the 3rd tail light turns off an on in the middle portion of the reflector. The panel is removed from the inside of the car, as the truck has metal surrounding the top area.
How do you remove the 3rd tail light to check for loose connections or to replace the bulb?
Thank you.
Thank you.
There's no bulb. But you have to slide it left to remove it.
I attempted to slide to the left, it does not move. Is this for a 2011 ES350? If so, do you push down and slide or just slide to the left (Passenger Side) Also, is the light, just one LED replacement part? Thanks
You just slide it. Try to slide it right.
Thank you. To the right was the answer.
The "LED" assemble is one piece. Does anyone have a good source to purchase this part. It is listed for over $300.00. Thanks
scribbler
05-23-16 02:58 PM
