ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
View Poll Results: What grade of gas do you use in your ES350?
Premium Fuel
43.18%
Mid Grade Fuel
20.45%
Regular Unleaded Fuel
36.36%
Voters: 44. You may not vote on this poll
Premium fuel or lower / Octane requirements (merged threads)
Old 05-15-16, 06:24 AM
  #121
jagtoes
jagtoes's Avatar
Originally Posted by 12jimmyjam
Being that the lexus engine "requires" premium and is rated at 272 horsepower versus the 268 that the toyota engine has, I'd guess that it would only give you 4 extra horsepower.
I think that lexus required premium fuel for the extra 4 horsepower to set it apart from the camry. But as an owner, I really wish that they would just say that regular is ok for our models.
Lexus changed the fuel requirement I think in 2011 and at the same time reduced the HP to 268. Other then the plastic cover the engines are the same for both cars. If you are using a name brand gas the detergents and additives will not be any different between regular and premium fuel.
Old 05-27-16, 09:30 AM
  #122
RXGS
RXGS's Avatar
I haven't noticed a large difference between using regular and premium, that being said when I used ethanol free 91, mpg went up between 2-3mpg a tank
Old 05-27-16, 09:41 AM
  #123
ESh
ESh's Avatar
I hear a lot od valve clatter on regular.
Old 05-28-16, 03:53 AM
  #124
mocanu
mocanu's Avatar
Regular works perfectly fine in my es350. Given that there are many who report that there are no problems with regular I would suspect that there are other factors involved in the reports of those experiencing problems.
As for an increase in mpg at higher octane it simply isn't worth the cost.
Old 05-28-16, 05:22 AM
  #125
jagtoes
jagtoes's Avatar
If you do then you have an engine problem and not a fuel issue.
Old 05-29-16, 01:20 AM
  #126
ESh
ESh's Avatar
Probably I would hear it on premium too.
Old 07-07-17, 01:51 PM
  #127
Freshjr
Freshjr's Avatar
Default Why premium gas? What difference in lexus 2gr-fe
Toyota popped this engine into many cars
-camry
-sienna
-RAV4
-Avalon
-rx350
why do the Lexus variants take premium gas only?
do we have different compression ratio or heads from Toyota versions? What's the deal.
Old 07-07-17, 03:50 PM
  #128
ESh
ESh's Avatar
You can put 87 and you'll notice no difference.
Old 07-07-17, 04:15 PM
  #129
Freshjr
Freshjr's Avatar
So will ECU adjust and pull timings? Or is ours programmed differently from the Toyota versions?
Old 07-07-17, 04:16 PM
  #130
ESh
ESh's Avatar
The ECU will change the timing.
Old 07-08-17, 04:30 AM
  #131
lgb0250
lgb0250's Avatar
I've been using 87 since the day I picked mine up new almost 8 yrs ago.
Old 07-08-17, 07:05 AM
  #132
Paul3637
Paul3637's Avatar
This is correct. Lexus started "recommending" regular I believe in 2012. When they did that, they lowered the horsepower rating from 272 to 268 .... same as the Camry.
Old 07-08-17, 03:55 PM
  #133
tolian21
tolian21's Avatar
The general trend in the industry is to require premium gas for luxury brands. Some of it has to do with getting higher performance numbers and also they know that people buying luxury cars usually do not mind paying extra for gas.
In 2012 ES350 was downgraded to premium, perhaps they also tweaked engine running, nobody knows. Its possible that horsepower was overstated and they had to scale it back.
Old 07-09-17, 09:18 PM
  #134
ThumperPup
ThumperPup's Avatar
living at a higher elevtion and were i am fuel grades are different then they are on the east coast or down south from when i grew up with 87 being the low regular grade
now i am in utah and 85 is the low grade regular fuel. i use 85 in my ES350 2007 model year for over 70,000 miles of driving and never have any problems.
i get great fuel mpg and great power from the car no issue.
once every 5,000 miles ill put a bottle of Chevron Techron in my tank and fill it up with premium fuel higher grade fuel and thats it
usualy do that just before a oil change
Old 07-09-17, 10:19 PM
  #135
chuyrobles
chuyrobles's Avatar
Me too. Our Lexus has never seen anything but 87, mostly Tier 1 87. If the engine don't knock, it's handling 87 OK.
Quick Reply: Premium fuel or lower / Octane requirements (merged threads)
